No Crank
Well Darn it! car started several times earlier in the day, then sat till night. Now won't start. battery is full and dash lights up, I can hear relays clicking when I turn the key, But No starter action at all.
I tried several DME relays to no change.
it doesnt even try.
it doesnt even try.
Can you test the starter itself? And chance the solenoid on the starter is not activating, or is that part of the clicking that you hear?
Cheers
Cheers
Ok just had a chance to check, cables look ok, and I tested the starter in place.
What ever click i hear when going to "start" position sounds like a relay.
You asked what the clicking sound was. I think it is your fuel pump.
As others have mentioned, you need to check whether your battery is getting juice from the alternator and whether the starter motor is getting enough juice. I do not know what the correct voltage to your starter should be, sorry...
I believe starter motors are rebuildable.
-Yogii
-Yogii
-Yogii
-Yogii
darn, was ready to run this test but apparently the 68 doesnt have this: http://forums.pelicanparts.com/porsc...-easy-way.html
I disconnected the ignition switch wire and "hot wired" it and still all I get is the 2 quick clicks from the bottom of the car.
So if it IS the starter solenoid i hear clicking, (and Now I think it is), despite the fact I got the starter spinning when giving it power directly (from my charger), But I couldn't give power to both the Solenoid and the motor at the same time. Could that still mean the starter is the issue?
