Speedline refinish 2008
#31
As you can see, the clear coat is missing. I pulled the clearcoat and along came some clear coat from the center section. This couldn't have happened if they were not clearcoated together.
Another pictures of the same damage. Fortunately, this is the only damage to any of the 4 centers.
Most people probably think I should get my head checked out since the set is in really nice shape. Here I am, taking it all apart to get it refinished.
Raj
#32
Mine are polished centers. Here are some pictures..
Raj
Raj
I see what your saying. It would appear they had several ways of making these and not so sure they have decided on which approach works best.
#33
Just a thought. Might be a good idea to run a sharp blade around the gap between the center and the outer before removing the bolts to keep from damaging the the paint on the center when taking apart (assuming the centers are not going to be redone).
RT
RT
#34
Center cap update.
So I got off the phone with Jeff and apparently these are all discontinued. Porsche recommends using the plastic 996 parts which i am not so sure fit. In either case I am not putting plastic caps on $6000 wheels. BTW pricing is on an upward swing.
Ebay seems to be the best source for the painted ones. Around $125 a set. be careful there are different vintages and the center crest can vary in color tremendously along with some versions having holes in them
For now I am going to strip the set I have and try polishing them to see how they look. If they look good i am set.
#39
Here is a tease - if all goes well I will again be a Speedline owner (well actually I am now but I only have (1) rear Aliseo wheel center and of course all my parts and knowledge). In a couple of days after the dust clears I will tell you more. These are paid for but not in my possession yet. I never imaged I would learn so much about these wheels or all the nuances in the proper way to finish/rebuild/restore. More to come I am sure.
Jim
Jim
#40
Jim
Jim
#42
#43
I was checking that out earlier. I am looking for the same period caps that came with the car.
Not as easy to find as you think. There are a few variants that look very similar. Some have different colored centers (too much copper vs gold) Some have holes in them and some have different grooves.
The only polished ones I have seen are on the cars here.
These are actually very close might even be the correct style but not polished.
http://cgi.ebay.com/ebaymotors/Porsc...spagenameZWDVW
The polished ones they sell aren't the right style i am looking for.
#45
I have several sets like I want but all painted silver and would prefer to spend the money to have a perfect factory set for a perfect set of wheels. I will strip the paint off of one of the spare sets i have from my C2 and try polishing them and then clearing them although for some reason I am not sure it is a straight clear on the center section and I want it to match exactly. These would be my show wheels vs my driving wheels ( now you know what a fanatic I can be) Although I seriously concours my car and I have to compete with Y65mph which is no easy task.
You never know sometimes things pop out of the wood work so they say.
