Self Adjusting Tappets Question
I know someone here will definitely know this - do the 3.6 turbos have self adjusting tappets?
I've noticed in the last 500 miles or so a much more tappety noise particularly when driving next to a wall say. Its not loud but definitely noticable whereas before it wasn't.
If the tappets adjust themselves then presumably I dont need to do anything? and if so how long before they adjust?
thanks
Anthony
thanks
Anthony
Unless someone changed the cam towers to 993 and use 993 hydraulic rockers, the rocker arms are mechanically adjusted in all 964 and earlier engines, including the turbo 3.3 and turbo 3.6. Typical adjustment is required somewhere between 10-15k miles depending on how it has been driven, sooner if the car is used on the track quite a bit.
Originally Posted by 911addict
Is tappet adjustment an engine out job?
A respected tuner told me not to bother adjusting tappets until you start to hear them...
Not a big thing to do yourself, first time it took me a whole weekend, now it takes about 4-5 hours, the adjustment is only 30-60 minutes the rest is changing oil, jacking up the car and removing stuff to make access easier.
