reduce lag?
Not the K27HF, perhaps the new improved version. I am still not willing to rule definitively (talk to me after 3 upcoming days at Mid Ohio and 2 at Watkins Glen) but I am pretty sure my K27HF increased lag.
I think all the others are better choices for reducing lag, though I only have experience with the lwfw. I think the lwfw is a must-do mod.
Originally Posted by mad
What is the best upgrade or group of upgrades to reduce turbo lag?
lwfw?
highflow turbo?
better gear ratios?
headers/exhaust?
others?
lwfw?
highflow turbo?
better gear ratios?
headers/exhaust?
others?
changing the final drive ratio will do nothing to decrease lag, it will just cause the car to run at higher rpms at a given speed thus keeping you in an rpm range where the car makes more boost
thus you see less lag
Originally Posted by 3.3 Turbo
Any recommended brands for lwfw? And how much does it cost?
Charlie, with the many written accounts of people reducing lag with the installation of the High Flow, you truely are the exception of the rule. Your turbine wheel and turbine housing A/R has not changed. Lag will only be increased if you are dumping boost, and aren't utilizing it.
