964 Turbo Forum 1989-1994
Paintcode amethyst methallic
Old 01-02-2021, 07:19 AM
johnnysegel
johnnysegel's Avatar
Originally Posted by bweSteve
Holy crap!! ...
The engine builder probably left for the night after putting the pistons on the rods, and then forgot to check the wrist pin circlips the next day.
Were ALL of them missing?
Help me out on the picture above, ... it looks like there is a rusty wrist pin circlip installed
Good thing you took your engine apart to check everything. That would have been some serious scoring on your cyl jugs
Damage piston
Last owner hade to much boost and damage the Piston, since then the car had been not running.
They have mounted new cp pistons, and it looks like the used some old circlips. 2 where not mounted properly. And the rust i Guess it comes from THE old circlips, because everything else looks fine.
The cylinder are also ok.
​​​​​​The Piston rings has not been grinded to correct measuments.
Parts missing is wastegate, k-jetronic injectors and housing and the camshaft housing "plate"(bad English).
I getting rid of k-jetronic for now and installing modern stuff.
But i Keep all the parts so i can get it back to original when its time to sell.
Johnny
Cleaned up.
heliolps2 (01-11-2021)
Old 01-07-2021, 11:56 AM
sdematt
sdematt's Avatar
Johnny, where are you located? Best of luck on this project
-Matt
Old 01-09-2021, 06:02 AM
johnnysegel
-Matt
Thanks.
Located in Sweden.
Full Winter here now waiting for spring.
I hope i get the car up and running this summer.
I also have a cup car who take some time during the short trackseason here.
Old 02-20-2021, 07:49 PM
johnnysegel
I was grinding in the rings to the cylinders and saw this?
Is the cylinders bad so just buy new ones?
It is there Any acceptable tolerence?
Johnny
Old 02-20-2021, 08:11 PM
cobalt
cobalt's Avatar
Received 2,170 Likes on 1,299 Posts
Looks to be out of round a common issue. Looks fairly significant but you might be able to have the nikasil chemically stripped and new nikasil applied and honed to bring them back into tolerance. Although you are measuring awfully high on the cylinder so it might not be as bad as you might think.
Old 02-21-2021, 03:56 AM
johnnysegel
Ok yes thought of that and i will check lower down how it looks. Thanks for answer.
Johnny
Old 04-07-2021, 01:56 AM
johnnysegel
Yes lower down it was no problem.
Anyone test E85 on aircooled porsche?
I am installing maxxecu and thinking going that way with flexfuel sensor and all.
Have read somewhere its not good for the cylinders ?
Have easy acces here and some extra hp is never wrong.
johnny
Old 02-03-2022, 07:39 PM
Scott Dunavant
Scott Dunavant's Avatar
I might own that car now. Did the car have a cel phone option?
Old 02-04-2022, 04:03 AM
johnnysegel
I still own it.
It is not any phone mounted in the car.
johnny
Old 02-04-2022, 04:15 AM
johnnysegel
Default Coming together.
I mounted ARP headbolts and rodbolts.
Scott Dunavant (02-19-2023)
Old 10-13-2022, 10:39 PM
Scott Dunavant
Any updates?
Old 02-25-2024, 05:08 AM
johnnysegel
Engine went back to stock etc.
Going into the car in a couple of weeks.
What clutches are you guys using?
I found this sachs one:
https://www.design911.co.uk/p/porsch...90-3000824901/
Stock Power, and maybe some small upgrade but not much.
Thanks.
Old 02-26-2024, 01:39 PM
urquattro20Vt
urquattro20Vt's Avatar
Sachs Sport clutch here
Brandon
'91 Turbo
Old 02-29-2024, 01:40 PM
sdematt
sdematt's Avatar
Looking forward to more pics!
Old 03-01-2024, 04:49 AM
johnnysegel
I get some pics next weekend when installing the engine.
Anyone has the wiring diagram?
Guess i might need it. I had it on a flashdrive that went broken.
The car has had a immobilizer/alarm installed wich has been removed.
I got the alarm parts in a box with the car, but i guess they just ripped it out!
Quick Reply: Paintcode amethyst methallic
