Body Restoration
This part has gone lost. I am sure I put it in with the rest for plating. The plater is sure they did not lose it.
Funny thing, both sides got lost.
Anyone have a spare (or two)?
As I mentionned above, 2 small door parts have gone lost. They are the axles of the fulcrum point that move the door lock ****, and the axles of the knurled **** in the door panel at the same time. I took the parts completely apart for plating, but these 2 disappeared along the way. As of now, I suspect I threw the away by mistake.
Anyway, Porsche PET: 320$ the pair. Right. Not happening either.
I have had this small modelist lathe for a long time. It is not very precise, but works OK for aluminum, and I can get close enough tolerances with careful setup. I took some 12mm alloy stock rod that I turned down to 10mm, threaded outside at one end and inside at the other, and cut the relief for the clip, then filed the square end for the turnknob.
The plate I cut out of steel plate, drilled for the rod clips and threaded for the axle. Assembled the 2 with loctite. Not the mechanically strongest, but I realise I never used the ***** to lock the door, with the central locking at the touch of a switch on the center console.
They are not as nice as all the yellow plated parts, but with a lick of paint will be presentable, and they are well hidden anyway.
Back to questions: does anyone have the details of the wiring for the license plate lights? I know the harness leaves from the lateral hole in the right rear light bucket, but I don't know its correct routing.
Discoveries:
-The left rear fender was at one time bashed in real good, likely from a rear-ender. It was about 10mm forward of where it should be. No wonder the rear light always fitted badly. All pulled back in line now. There is still a crease, and the plate covered a hole in the fender. Still some work to do, including metal forming.
-There were...... 11 layers of red paint on the rear left fender
-The rear window frame has been repaired in the past, but from overzealous grinding, the sheelmetal has worn through. Not rusted now, only worn so thin it actually disappeared on the edge.
-The right rear fender had a few holes high up, that line up with the foam that is placed in to avoid water splashing up into the C pillar.
-Small rust damage on the sill by the driver door, already repaired, needs to be leaded in.
Otherwise not many surprises. the work should be done by November, with some subtles mods.
Pics below.
FYI there is a guy in the UK that does pretty much a full set of replacement tubular steel supports for £130 inc a few not shown in your pics - let me know if you would like his contact details.
You want the one on the left if you can have them made that way.
They kept the nasty left rear fender and rear window frame for last, when they are well in the groove. Me Happy.
