100000 Miles service, do it your self.........
#46
Now I start to drain alll the oil from the engine, tank and gear box.
First make a small 5 mm hole in the top of your oil filter before replacing it. This is for some air into the filter, for the oil that will go back to the tank, otherwise all the oil from the filter will drain in the engine bay...............
Then drain the oil tank, on the right rear side just in front of your rear wheel.
Some WATER will come first.................. THIS IS NORMAL!!!!
#50
Now we come to the nicest work from today, cleaning the oil filter area.......................................
PLease turn then new filter with your hands, no tools allowed!!!!!!!
Some brake cleaner will help cleaning that area, please use also compressed air for drying the area.
#51
Yes I did use plenty of paper in the picture before, it's never enough............
Please secure the floor with some plastic, you will need it!!!!
See you next update!
#52
Thanks Rob, I hope people will enjoy it. I will do my best to make as much pictures possible. May be it helps.
Now I have some time with my wife and kid, so then everybody is satisfied......
kos11-12 (11-02-2020)
#56
I have the tool to replace the oil pressure sender, so I will do that tonight. It's like a wrench who's head is cut off. No space for a normal wrench 24 mm metric.
After that, I start to remove the valve head covers for the adjustment of the valves.
#59
Now we come to the valve area.
Please remove all the dirt around the valve head covers.
Remove all the sprak plug cables and tight them with some ty raps.
Then unscrew the nuts from the covers.
REMOVE THE VALVE HEAD COVERS ONLY BY HAND, USE NO SCREW DRIVER.
USE A SMALL PLASTIC HAMMER WHEN IT GOES HARD. gIVE A FEW SOFT BUMPS AGAINS THE SIDE OF THE COVERS.
The upper valve head covers needs to be cleaned very well because some dirt can fall in the valve train area.
Before removing the spark plugs, use some air to remove dirt out of that area. Then remove the spark plugs.
#60
NOW WE COME TO THE NUMBER 6 SPARK PLUG WHO EVERYBODIES FEAR AND HATED PLUG.
GUYS, ........NO PROBLEM, TAKE IT FROM BELOW WITH TE RIGHT TOOL.
SEE FOR YOUR SELF.....................
