90 C2 964 plug ID
90 C2 964 plug ID
https://rennlist.com/forums/images/a...attach/jpg.gif
Hello I am looking to I.D. this plug on the drivers side of the car(US) in front of the heater blower which I have removed. When installing the left hood plunger I brushed this plug and it fell apart because of heat. I kept note of the wire colors and reinstalled the wires to the other hald and used silicone to keep the wires from touching each other and a zip ty to the other wires to keep from grounding. Started the car all is well. The black plug in issue goes in front of the green and white plugs. The plug with my little finger on it is the 02 sensor. The plug in question comes down the drivers side goes into the broken harness shown and goes back down into the body in front of the intake manifold this is the grey wire with the arch to it .Any input or qwuestions please send a line thanks Randy
Green = bank 1 knock sensor
White = cylinder head temp sensor
Black = flywheel reference sensor
Read this thread.
https://rennlist.com/forums/964-foru...ce-sensor.html
Whoever did the sensor swap on your car wasn't quite as meticulous as the poster in this thread.
Read this thread.
