964 Forum 1989-1994
speakers !!!
Old Oct 9, 2003 | 09:53 AM
ian c - u.k's Avatar
ian c - u.k
Registered User
Default speakers !!!
standard size to fit on doorcards ....................
any suggestions ?
Old Oct 9, 2003 | 10:08 AM
Andy Roe's Avatar
Andy Roe
Ian,
You'll need 13cm speakers. I got some Infinity Kappas & I'm very happy with them. Did not bother replacing the crappy ones on the back shelf. Instead to get some more bass, I fitted an Active Subwoofer under/behind the passenger seat (LHD). Very happy with the result!
Andy
Old Oct 9, 2003 | 10:54 AM
Phil Raby's Avatar
Phil Raby
Originally posted by Andy Roe
Ian,
Andy
Hi Andy
Be interested to know more about your subwoofer installation. My bass is very poor.
Thanks!
Old Oct 9, 2003 | 11:00 AM
robmug's Avatar
robmug
Ian - I'll check later, but I fitted Infinity speakers which were, I think 6.5 inches. This is significantly bigger than the original speakers (5.25 I think), but they fitted the same holes. Wierd I know, but it is to do with the mounting points. I'll check the exact model later.
Old Oct 9, 2003 | 11:04 AM
Phil Raby's Avatar
Phil Raby
I also have Infinitys - fit straight in and don't look out of place.
Cheers
Old Oct 9, 2003 | 11:06 AM
ian c - u.k
Registered User
rob ........... cool ...............
gives me a bit more choice if i can go bigger without ruining the cards
also , my cards are "crested" , so is the tweeter the same size ??
Old Oct 9, 2003 | 11:12 AM
Jim Howley's Avatar
Jim Howley
Seems like the Infinity speakers are a popular choice as I also have them and am very happy with them.
One thing I did find is that installing good speakers in the front emphasised the lack of speakers in the back. I am not in the habit of making my friends squeeze into the back of my car but occasionally I have needed the rear seats so did not want to lose them completely to a rear speaker install. As a result I have constructed a box which contains a set of 6"x9"s and sits on the folded down seats. The box is carpeted and is attached to the seats using heavy duty velcro to stop any movement. The speaker cables connect to a quick release connection box so if I know I am going to need the seats or the space I simply unclip the cables and lift the box out.
It's not ideal but it suits my needs and once the car is off the road a bit more over the next few months I intend to redo the same installation with a few extra improvements.
Jim.
Phil Raby's Avatar
Phil Raby
Mine are Infinity 552i
Old Oct 9, 2003 | 11:13 AM
Andy Roe's Avatar
Andy Roe
Phil,
I fitted a small clarion sub partially under, partially behind the passenger seat (LHD). Made a big difference & worth every penny of the £130 is cost me.
Only down side, is that you can't move the seat all the way back - perhaps lost a couple of inches in leg room, but I thought since I never sit there...
Upsides are great bass & a free massage for the passenger!
Old Oct 9, 2003 | 11:14 AM
Phil Raby's Avatar
Phil Raby
Thanks Andy. When you say 'partially' does that mean it takes up space in the rear footwell?
Cheers
Old Oct 9, 2003 | 11:41 AM
rutz964C4's Avatar
rutz964C4
I installed Focal in the front and Alpine amplifier under the passengers seat my next step is to get more bass with a subwoofer but I am looking at several options, the first one is to place it behind the drivers seat (like audio innovations) which leaves no leg room at least on one side, the other option which someone posted some photos not very long ago is to fit the subwoofer on a side right behind the window, this didn´t take any space at all.
ALEX
Andy Roe's Avatar
Andy Roe
Yep! A little, but I've still have people sitting in there since, just a little mor cramped than usual. I've got the floor mat on top of the sub - you'd not know it was there!
Old Oct 9, 2003 | 12:00 PM
robmug's Avatar
robmug
I bought the Infinity set, which included the main speaker, the tweeter and the crossover, which fitted into the same place as the original. The tweeters fitted exactly into the same mountings as the original tweeters, though I seem to remember turning one peice upside down.
Old Oct 9, 2003 | 12:15 PM
robmug's Avatar
robmug
Without checking (I've just done a quick search online) I believe that my Infinity speakers are the 60.5cs.
http://www.audio-warehouse.com/web/m...5cs/detail.asp
Old Oct 9, 2003 | 12:31 PM
Jared W.'s Avatar
Jared W.
Hi,
I went for Focal Utopia speakers up front (5 1/4 components). Both the woofer and tweeter fit in the same spot as the stock speakers. I have a Mcintosh MX406 head unit, Mcintosh 420M amp in the "trunk", with an Alpine V12 amp (also in trunk) powering an 8 in. subwoofer. For the subwoofer, I used the "velcro" method already mentioned above. The sub box sits on my folded down rear seats, and can be removed easily if needed (it only sits atop one seat, leaving the other available. I only have to remove it if I need both seats. Hasn't yet happened, as I don't have two midget friends to fit back there).
