964 Forum 1989-1994
DIY - Replace Center Console Lights with LED's
Old 12-05-2014, 07:55 PM
RicardoD
RicardoD's Avatar
ToreB is the man. I just ordered my kit. Didn't realize my lights were dead until this thread. Taking my daily driver C2 one step closer to perfect working condition.
Old 12-05-2014, 08:16 PM
vagluv
vagluv's Avatar
same here! and yeah, Tore's stuff is great. He's an asset to our community.
Old 01-26-2015, 09:36 PM
vagluv
vagluv's Avatar
I stood around while Tom (tfitch03) did this mod for his car and mine yesterday and there are a couple of things that will be good for others to know. The kit does not have all the right parts if your car is a 964 C4. The kit comes with 3 red LEDs, 3 green LEDs, and 2 resistors. On the C4 you need 4 red LEDs, 2 green LEDs, and 3 resistors. The lights above the dials are green, and there is a red flasher for the awd system. We made a run to a local electronics store to grab the extras, which was no big deal bc they're extremely cheap. The other note is that the bottom light board has different polarity than you'd expect after looking at the pics on ToreB's site. Positive on pins 1 and 4 in the connector, and negative on pins 2 and 3. Also, there isn't much room once you put the board back into the switch assembly, so the way we did it is really the only way the resistors are going to fit once you put it back together.
Old 01-26-2015, 09:46 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by pi5tolpete
Where did you source the 12v LEDs?
Any RadioShack in North America will have them in stock at ~$2USD, part #276-209.
Old 01-26-2015, 09:57 PM
DobermanDad
DobermanDad's Avatar
I'm doing this mod.
Old 01-27-2015, 10:22 AM
DobermanDad
So if I do this with 12v Leds, I don't have to use any resistors?
Old 01-27-2015, 10:45 AM
tfitch03
tfitch03's Avatar
Correct me if I am wrong Vagluv or whoever but I think yes, you will need a resistor.
I cant remember 100% but I feel like the Red LED we purchased, and the one you see in the above picture, is a 12v and we tested one without a resistor and it popped. We popped a few so I might not be remembering that correctly.
Big help I am!
Old 01-27-2015, 11:51 AM
vagluv
vagluv's Avatar
Big help I am!
The packaging did say something about 12v, but we did still need a resistor on that bulb.
Another tip: if you look at my picture, you can see that one of those bulbs is further out than the others. Once installed, that light is not an evenly glowing green, but has a bright spot. I would recommend making the base of the bulbs flush with the green board to avoid this.
Old 01-27-2015, 12:44 PM
tfitch03
tfitch03's Avatar
Calling out my skills on a public forum?!
I can fix this weekend or during the next tech day at my place.
Old 01-27-2015, 02:39 PM
Harry Apps
Harry Apps's Avatar
No you don't. See my Post 3 above.
Old 01-27-2015, 05:09 PM
davidwilson11
davidwilson11's Avatar
Oh no, I bought a kit from tore. Unusual from tore that's it's wrong. I'm sure he will chime in.
Old 01-27-2015, 07:33 PM
vagluv
vagluv's Avatar
No I wasn't. Your skills are infinitely better than mine!
Old 01-27-2015, 07:34 PM
vagluv
vagluv's Avatar
His kit and write up are perfect for a 993, and give you everything you would need for a C2.
Old 01-28-2015, 03:30 AM
ToreB
ToreB's Avatar
Hi guys, thanks for all your support.
I haven't been aware of this extra lamp power feed in the 964, and will update the kit contents and installation manual to cover this.
I will of course supply any missing bits to anyone that need it. If so, PM or email me.
Cheers,
Tore
Old 03-13-2015, 03:31 PM
DobermanDad
Need help. My lower board is different. I got the top all done. Pretty straight forward, but....
i'm thinking it may need two resistors?
Quick Reply: DIY - Replace Center Console Lights with LED's
