The silly little question thread ...
#571
#572
From reading some other threads on people having the blower on to cool the engine after the car shutting off, I was wondering what fuse is responsible for that in the engine compartment?
Also, it seems one my fuse box covers has the plastic cover spinning in place. Whats the best alternative, dremmel it off, or try to pull off the plastic 'nut' and maybe use pliers to unscrew.
#573
I really hope this is a "silly little question".....
These lights popped on today during my commute to work (10minutes). Tried searching but little popped up. some say relay, some say sensor...anyone know or do I need to have the car scanned to figure it out?
#575
I'm happy to lend a hand bleeding if you feel like trekking up to Fairfield for a day...just bring five liters of ate200 and a lot of patience.
#577
How do I check this? Still pretty new to these cars. Thanks guys!
KW install and rear left cv boot replacement.
I assume non of this would have affected brake fluid/pressure???
Thanks for the offer....I may take you up on this....let me figure out how to check the reservoir first.
I'm going to say you need to look at your brake fluid. Very likely you have air in the system or your pressure bomb isn't pressurizing...try bleeding the system. You had it in a shop recently didn't you? What did they do?
#579
#582
#583
Just went out for a drive and now the lights are off. Will still get it scanned later today but could it have just been a fluke??
#585
Control Unit: PDAS
Fault Code: 0005
Not Active (as we know since the light turned off on its own)
Description: 50502 Fault Memory Entry Not Documented
I guess this will all be a mystery for now...
