964 Forum 1989-1994
The silly little question thread ...
Old 05-25-2024, 01:53 PM
  #2131
JohnK964
JohnK964's Avatar
just by the nature of what they are made out of requires a bit of wrestling
Old 05-25-2024, 02:29 PM
  #2132
Balisong
Balisong's Avatar
Tuck it into the fender lip first. Then you can apply pressure to the reinforced area closest to the trunk to slide it into place.
964Luftballoon (05-26-2024)
Old 06-16-2024, 11:32 PM
  #2133
John McM
John McM's Avatar
I’ve been cleaning up and found this key. I think it might be for wheel nut locks but I can’t find mine to test. Does anyone else have a similar key, and if so, what does it open?
Old 06-17-2024, 05:07 AM
  #2134
cjoenck
cjoenck's Avatar
Yep, looks like mine for one lockable wheel nut on each wheel. I replaced mine because I was afraid the road gunk would destroy the lock and the key would work when needed. Who would steal a D90 wheel anyway?
John McM (06-17-2024)
Old 06-17-2024, 07:13 AM
  #2135
John McM
John McM's Avatar
Thanks. I suspect these were for the lock protecting the Speedlines on my Turbo 3.6. I sold it 10 years ago so I think I would have heard by now if there were issues
Old 07-18-2024, 05:01 PM
  #2136
No_snivelling
No_snivelling's Avatar
Default Slow tire leak
I have a slow leak in rear tire. It's a PIA to add air once a month and I really don't want to risk rim damage by taking it to a tire shop. What's the current thought on liquid sealants like Slime?
Old 07-18-2024, 10:47 PM
  #2137
cobalt
cobalt's Avatar
Received 2,181 Likes on 1,305 Posts
I think the name speaks for itself.
Old 07-22-2024, 06:45 PM
  #2138
edvc520
edvc520's Avatar
Just got rear ended over the weekend but have found two part numbers for the bumper… anyone know the difference?
964.505.023
964.505.123
its for a North American 964
thanks
Old 07-22-2024, 06:56 PM
  #2139
Tomfun
Tomfun's Avatar
964.505.023
964.505.123
thanks
The bumper is made up of three sections, .123 is the center section. 964 505 163 00 is the right and 964 505 164 00 is the left. You should look at the pet though, the bumper is comprised of many pieces.
Tom
Old 07-23-2024, 05:19 AM
  #2140
LM964
LM964's Avatar
964.505.023
964.505.123
thanks
As Tom - rear bumper has a few sections (i.e. exhaust cut-out types etc). Your numbers likely referring to the centre section. Basically two types - RS / 3.6 Turbo or the rest. The difference being the RS type is not a full (horizontal) 'flat line'' side to side. That is, the RS centre section has a full recess into the bumper where the reg plate is fixed . I fitted an RS centre section to my rear bumper as I just didn't much like that continuous line across the rear - each to their own and just a personal thing. Popular in the EU.
With the standard or non-RS type there are other world market design variations that accommodate a smaller or larger reg plate type of that region. These too may possibly have varying part numbers specific to that region, so worth asking your local OPC parts dept if that is the case.
Old 07-23-2024, 09:38 AM
  #2141
cobalt
cobalt's Avatar
With the standard and non-RS type there are other world market small design variations that accommodate a smaller the larger reg plate type of that region. These too may possibly have varying part numbers specific to that region, so worth asking your local OPC parts dept if that is the case.
The North American center section is the same for all models. It has a smaller center opening for US plates and uses a different lamp for the plates. It would appear it isn't listed in the PET but the proper US center section part number should be. 964.505.023.01. I believe the 123 is the RoW center section.
Here is the standard US center section compared to a RoW Turbo 3.6/RS center section there is also a standard N/A RoW center section that is just flat across. The entire back. These all use different crash bars with hole placement for the tow hook in a different location and different plastic pieces that protrude to help the cover in case of a minor tap.
ROW Turbo/RS top. US spec all models bottom. Note that the US spec center has a full overhang over the plate and will warp over time so make sure you buy a used on that isn't already warped.
Part number on backside of the Blue US spec center section.
Old 07-27-2024, 07:36 PM
  #2142
jeff33702
jeff33702's Avatar
https://www.design911.com/p/brake-ca...orsche-993-c4/
question - I am trying to buy new 993 rear calipers for my 964 but I wanted them in silver. I initially thought these being part number .2x at the end made them silver but otherwise they were the same. I see they are listed as OE C4 (not c4s) - are these going to be ok for my conversion on a 964 nb?
Old 07-28-2024, 02:01 AM
  #2143
_Remi
_Remi's Avatar
I am trying to temporarily re-install my engine tray since I will be using someone else's parking for a few months and would like to avoid small drips. The two screws in the back and the three screws on each side went fine but I could not screw the five or so at the front. I removed everything and realized that these supports don't have a thread which is not super clear in the PET. Am I supposed to use a nut?
Old 07-28-2024, 02:54 AM
  #2144
Spokes
Spokes's Avatar
You need speed nuts.
Old 07-28-2024, 05:16 AM
  #2145
LM964
LM964's Avatar
Quick Reply: The silly little question thread ...
