REDTEK Engine Build
#106
The fan has very visible pitting which is even apparent in the pic, is that normal? it was stripped and apparently a lot of them look like that and have corrosion under the paint.. but it looks a bit crap.
#111
The fan is mag and once the factory coating (such as it is) is disturbed the fan begins to corrode. Check your pitting- if it's deep and/or at the root of a/the blade(s) you may wish to consider replacing. Recently a member here showed photos of what happens when the fan energetically disassembles itself; ungood!
#114
Car is finally back.. Engine done!! Redtek were great, highly recommended.
For more of an update see my car thread :
https://rennlist.com/forums/964-foru...lution-10.html
