964 Forum 1989-1994
964 coil removal
Old 08-18-2013, 08:21 PM
rsathre
rsathre's Avatar
Default 964 coil removal
Okay guys. I'm a novice mechanic looking to change the coils in my 1990 c4. How do I remove the coil from its braket?
Thanks in advance.
Old 08-18-2013, 09:07 PM
abarthguy
abarthguy's Avatar
Ignition coils or suspension coils ??
Old 08-18-2013, 09:11 PM
rsathre
rsathre's Avatar
Ignition electrical coil. Sorry
Old 08-18-2013, 09:30 PM
Vandit
Vandit's Avatar
Okay, this is kinda tricky when you're unfamiliar. It's easier the 2nd time. Basically, there's one clamp-like bracket that holds the both coils in place. You can't see the the fasteners because they're behind the bracket where the ignition modules sit. You stick a 5mm hex key through a hole between the ignition modules to get to one of the fasteners. The other fastener is ahead of the rearward ignition module, so basically immediately after the rear fusebox. You don't have to completely remove the fasteners which is good, since reinstalling them becomes a pain since you're working so blind. Just loosen both of them a bit, little by little, until you loosen them enough to be able to pull the coils out the top of the bracket.
Once the coil is out, you can unclip the protective hat, remove the ignition lead, and then there's a couple of really small nuts on the top holding the top holding the power leads to the coil.
Obviously, you have to remove the heater blower before anything else.
Old 08-18-2013, 11:19 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
This might help? Hopefully somebody else has a photo showing them both removed.
Old 08-18-2013, 11:42 PM
Vandit
Vandit's Avatar
^That's a good pic.
You see that hole between the two ignition modules? That's where you stick your 5mm hex key. The 2nd hex fastener is just out of the frame to the left. You need to remove the cover to the rear fusebox (3 10mm plastic nuts) in order to get a clear line to the fastener.
Old 08-19-2013, 09:59 AM
FeralComprehension
FeralComprehension's Avatar
In cases like this PET can be invaluable- if you look at the PET diagram you can see how the bracket works, which will help you to take it apart.
Old 08-19-2013, 09:08 PM
JasonAndreas
Technical Guru
Somewhere on Rennlist I posted a lot more images, here's the image from PET.
Old 08-25-2013, 07:38 PM
rsathre
rsathre's Avatar
Thank you everyone. Here's the next question. I changed the two coils out. Connected everything together, and cranked the engine and nothing. Sounds like it does when battery is dead. Should I just jump start it?
Old 08-25-2013, 08:23 PM
darth
darth's Avatar
I'm confused, if the engine cranked (i.e. turned over) but didn't start, the battery is not dead. If in fact, the engine did not crank or turn over, the battery is likely discharged or there's a bad connection. It's gentler on the alternator to charge the battery with a bench charger 1st, rather than allow the alternator charge the battery.
Old 08-25-2013, 10:45 PM
rsathre
rsathre's Avatar
The engine did not crank at all.
The battery was working fine before I started my coil replacement project.
Old 08-25-2013, 11:23 PM
darth
darth's Avatar
What caused the battery to discharge? Why were the coils replaced?
Old 08-26-2013, 12:03 AM
rsathre
rsathre's Avatar
That is exactly my question.
The battery was fine.
I changed the coils bc I was getting some hesitation with the engine sounding like it was skipping for a second when pushed hard and warm.
When I hooked everything back up together, battery was discharged, or so I think.
I did not disconnect battery while working on the coils.
I don't know if that tid bit affects anything.
Old 08-26-2013, 12:34 AM
darth
darth's Avatar
Does anything power up on the car - dash lights when you turn key , radio, lights etc.?
Old 08-26-2013, 01:45 AM
rsathre
rsathre's Avatar
Yes...lights and click etc power up.
Quick Reply: 964 coil removal
