964 Forum 1989-1994
Need Help Motor sounds clicky
Old Aug 16, 2013 | 06:18 PM
Enso's Avatar
Enso
Default Need Help Motor sounds clicky
Im hoping my fellow wizards can help me diagnose this motor clicky sound
to me it sounds like a leaky head gasket or leaky exhaust
i dont think ts the exhaust because ive had the exhaust off and installed new gaskets
i also have an oil leak coming from the left top by the the base of the distributor
here is a youtube video
any help is appreciated
glenn
Old Aug 16, 2013 | 06:25 PM
Indycam's Avatar
Indycam
All I see is a gp white in a white out snow storm .
Old Aug 16, 2013 | 06:27 PM
Vandit's Avatar
Vandit
Probably the timing belt tensioner cap. Easy fix. 2 10mm nuts and an inexpensive gasket.
Old Aug 16, 2013 | 06:28 PM
Vandit's Avatar
Vandit
Old Aug 16, 2013 | 06:36 PM
Indycam's Avatar
Indycam
If you put your hand with a rag over the exhaust pipe , blocking the flow out the tail pipe , with the motor running , does the exhaust make it out the leak ?
Old Aug 16, 2013 | 08:14 PM
darth's Avatar
darth
It appears you have a head leak. Check if you have any loose or broken head studs.
Old Aug 16, 2013 | 08:36 PM
Enso's Avatar
Enso
i thought it might be one of the heads leaking does this mean dropping the motor and if needed head gaskets and head studs?
thanks
glenn
Old Aug 16, 2013 | 09:15 PM
darth's Avatar
darth
It does.
I would verify further (i.e. by removing the valve cover and check if studs are loose or broken - tighten if loose, compression/leakdown test, check if you can feel the compression leak around the head with your hand, find the source of the oil leak - likely one of the front cylinders on the left side) before dropping the engine, as it's no small task. Also, limit running the engine in this condition.
Old Aug 16, 2013 | 10:06 PM
Vandit's Avatar
Vandit
Everything i've read suggests that re-tightening the heads on these cars is not advisable.
My car makes a similar racket and it has dampness on the cylinders.
Old Aug 16, 2013 | 10:39 PM
BigMikeATL's Avatar
BigMikeATL
Sounds like a VW bug
Old Aug 17, 2013 | 07:58 PM
Enso's Avatar
Enso
Originally Posted by darth
It does.
Thanks Darth i think i'll remove the valve covers check the studs then do a leak down
best
glenn
Old Aug 18, 2013 | 06:29 AM
Zingari's Avatar
Zingari
This sounds more exhaust related to me? It doesn't sound like a tappet where in my case there was a definite metallic clicking heard from the left wheel arch.
I caught mine in time as it turned out to be a rocker bolt coming loose which had thrown out the valve timing.
Old Aug 18, 2013 | 11:26 AM
Enso's Avatar
Enso
In February i had reset the valve lifers and didn't notice anything lose
i not check the studs though
this sound has been going on for a while
glenn
Old Aug 19, 2013 | 10:03 PM
jgrosjean's Avatar
jgrosjean
Sounds to me like an exhaust leak. Maybe one of the gaskets on the head or in the exhaust system. Take a piece of rubber hose, stick one end in your ear and probe around with the other end. You can find out exactly where it is.
Old Aug 20, 2013 | 10:03 AM
Enso's Avatar
Enso
thanks for the hose tip i had the exhaust off last winter and installed new gaskets (this sound has been going before the new gaskets)
i will try the hose trick thou
thanks
Glenn
