964 Forum 1989-1994
No A/C
Old 04-28-2013, 08:09 PM
tokoro
tokoro's Avatar
Default No A/C
When i press the compressor button i heard the fan in the driver front part but not cold air comes out!! How can i see if is the compressor in the engine not working??
Old 04-28-2013, 08:39 PM
993James993
993James993's Avatar
If there is no cold air you probably have a freon leak. My '90 had leaks at the compressor motor and at the expansion block.
Old 04-28-2013, 09:54 PM
cjoenck
cjoenck's Avatar
You can see the compressor clutch engage in the back of the compressor. You can also hear it engage with a click, cycling on and off if everything works.
Old 04-29-2013, 02:51 AM
ToreB
ToreB's Avatar
No cold air probably is due to a A/C leak. No air flow at all with fans running probably means one or more inert HVAC servos. Have a look here:
http://www.porschehvac.bergvill.com/
Cheers,
Tore
Old 04-29-2013, 03:20 AM
hamah
hamah's Avatar
Assuming it is a leak a leak test will identify the location of the problem. Another likely suspect is the evaporator which is a fairly lengthy process to R&R.
Old 04-29-2013, 07:36 PM
AB-Oz
AB-Oz's Avatar
I've given up on my A/C.
I had the valve/seal/thingys replaced to use the new/safe gas, had a leak test done, had cold air for 1 season, then no cold air after that.
Now I just wind down the windows or open the sunroof, and dont drive it on hot days...
Old 04-29-2013, 10:55 PM
tokoro
tokoro's Avatar
Yes the fan work perfect just not cold air
check the relays and fuse in the engine compartment fuse box everything ok.
now i will do the pressure test
Old 04-29-2013, 11:12 PM
tokoro
tokoro's Avatar
Which compressor is better ??? sanden or denso? i think both are made in japan. but how can i see which one is better like does they have something that id them like more BTU they say that both are better than the stock one!!
Old 04-30-2013, 12:39 AM
David A
David A's Avatar
Have a look here too:
http://www.griffiths.com/porsche/ac/964ac/index.html
Old 04-30-2013, 02:37 AM
perelet
perelet's Avatar
Did you checked that you a/c fan is working? It is located in front part of dr side fender. You can hear it and also feel air coming out of the vent below it.
If not working it maybe fan resistor - they do get bad.
Oleg
Old 04-30-2013, 09:55 PM
tokoro
tokoro's Avatar
Yes it is working, the compressor I think is not activating
Old 04-30-2013, 10:50 PM
carlskisWP
carlskisWP's Avatar
If the compressor clutch is not engaging (spinning) likely cause is too low pressure of refrig. If you are sure that there is no freon left in the system, i.e., it all leaked out, you may want to consider what I did - using a 134a substitute to recharge through the low side port. What I used is hydrocarbon (butane) based so if it leaks out fast or even slowly it won't harm the ozone layer. My AC has been blowing cold since I recharged it. I didn't want to go through the process of converting the system to take 134a (and have it still leak) and I didn't want to put freon 12 in a system that might leak (which I think is illegal). There are some pros/cons on these freon substitutes so I suggest do some forum/google research. But it worked for me.
Quick Reply: No A/C
