1990 Carrera water leak
I have a1990 Carrera 4 that has water in the driver side foot well in front and back I do not know where the water is coming in need help finding the leak
Is yours a coupe, targa, or convertible?
Most times its the drainage holes are 'plugged' and cannot dissipate the water. One is under the car ~ kind of like under the passenger seat ish area if your going to see it. Hard to describe but its in Adrian's manual. Secondly, open the rear engine lid, and on either sides you will see a black nipple like hole, and its worth checking those aren't clogged either.
Try to search, there are a bunch of threads on the subject that could help more than my description.
Black 1990 coupe carrera 4, I will look at the drains in the sun roof, thanks for the tips on the drains, havn't heard about those, all new to me!
Thanks for the advice...
IHI KING!
Water in the footwell is only a symptom. You need to find how the water is getting in and fix that. Otherwise, drying it out is only temporary. For me, it was clogged water drains in the HVAC box. But also check your seals around the windshield, doors and the door & sunroof drains.
https://rennlist.com/forums/964-foru...ater-vent.html
Good luck with the repair and keep us posted what you find.
Several places that can cause water ingress into the car....at least in my experience.
- hood seal - this caused water to enter into the trunk and into the hvac box and eventually dripping onto my passenger foot through the foot vent.
- clogged hvac drain - this can cause the hvac box to fill up and drip into the inside of the car
- sunroof drains - this can clog and cause water to to drip into the car
- door panel water barrier seal - this will cause water to drip into the card at the edge where the door panel meets the door.
These 911s can't seem to keep the oil in and water out!!!
