Engine mounts?
#31
Little update.
Fitted new engine mounts couple of weeks ago.
Not really driven proper till sunday, north wales run.
Car is loads better to drive at pace, the engine must of been throwing itself around the engine bay.
Much better.
Much better.
#33
Ray (and/or others)
Just to throw some more information out there...here's a link to my m.m. install and impressions. It's a wonderful product!
Wevo m.m. installed - impressions: https://rennlist.com/forums/showthre...ferrerid=19642
I took a couple pics tonight. Based on other thread pics I think mine are shot.
#34
Look it to me, they look like the ones i removed.
When i turned at pace the car would turn then a milli sec later youd feal the car settle.
Hard to explain.
But the second movement must of been the engine slumping around!
Now you turn and the whole car turns as one, no second slump/movement.
Hard to explain.
#35
Go for RS, Type 911 do them for around £255 all in including bolts. there is a bit more vibration but not in a way that detracts from comfort for me... just feels more connected.
#37
I have black wevos and the Rennline carrier reinforcement ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
You don't need to drop the engine but you do need to support the engine with a jack (and jack stand just in case...) while your carrier is out. Remember you'll need to repaint the reinforced carrier with heat tolerant paint too.
#43
That's brilliant advise chaps. I'm going WEVO blue eventually but the carrier piece turns it from a simple DIY to a bit of a nightmare...Is it easy to remove the above yourself/ how long approx?
It would be rude not to paint it red whilst it was out
![w_attention](https://rennlist.com/forums/graemlins/attention_whore.gif)
#44
It might be depending on your definition of nightmare- definitely have to pull the rear bumper, rear most exhaust canister and the rear tin. Yeah, that was kind of a pain. Not sure I'd put in Wevo (great company and great support) blues without the reinforcement plate though- perhaps others that have experience and can speak to that.
#45
Regarding installing the Rennline reinforcement piece. Check my thread.
https://rennlist.com/rennforums/showthread.php?t=690433
Lots of slippery slope while-i'm-in-there potential along the way w/ this project.
