Engine mounts?
...so if you wanted to treat yourself, it's not quite in the same league as convicing your significant other that you really need coilovers
If anyone's interested I have a pair of low mileage genuine 964 standard mounts for sale (I put them on to replace my worn out originals but then decided to go RS).
Wevo products are available in Euro also....TwinSpark Racing is the exclusive European distributor for WEVO Porsche parts. (no affil)
The best text on Wevo's website regarding the benefits of upgraded motor mounts comes from their 997 section. However the same benefits apply to the 964:
The WEVO 997 SS Engine Mount is designed to offer more precise control of the drivetrain mass. Our experience with the whole family of SS Mount products has illustrated that most drivers experience the sensation of the drivetrain unit moving relative to the chassis mass. The drivetrain in a Porsche is independently suspended from the sprung mass of the car via the compliance in the engine and transmission mounts. This drivetrain assembly represents approximately 25% of the sprung weight of the car. The opportunity for forces to move the drivetrain comes from many inputs, such as the torque reaction of vehicle acceleration loads, the bumps and variations in the road surface and the lateral forces created in cornering and braking. That degree of independent movement of the drivetrain is responsible for some of the “sloppy” feeling that is evident when the performance envelope of the vehicle is explored. The higher the forces, the higher the deflections in the hydro-elastic mounts, therefore the deflections and movement of the drivetrain mass begin to operate out of phase with the movement of the car as a whole. For Racing the factory eliminate the hydro elastic mounts and install solid engine mount positions – marrying together the mass of the drivetrain and the sprung mass of the car. While solid mounts might be considered a conventional wisdom for a race car, this practice has an enormous impact on NVH (Noise Vibration Harshness) making it totally impractical for a street driven car.
The WEVO 997 SS Engine Mounts skew the performance intentions of the O.E. engine mounts and control movement by allowing smaller deflections under the same loads. Your drivetrain remains “independently suspended” but managed by a much stiffer suspension – much like stiffer dampers, anti-roll bars or springs could replace the original parts in your front and rear axle suspension configurations.
Unlike solid engine and transmission mount systems, the Semi Solid installation has no metal to metal contact and retains sufficient isolation from engine vibrations to protect your sensitive engine control electronics, sound system and instrumentation systems.
Like all deviations from the original design, there is some compromise. In this case the compromise is the potential for extra noise and vibration to heard and felt in the passenger compartment. Our testing has indicated that the change in NVH is a fair exchange for the performance improvement. A tighter feeling chassis, one with quicker left- right response, more predictable gear change precision and stability under braking. In essence, if you have modified your car in any way, loud exhaust, aftermarket suspension, lightweight seats, lightweight interior….any of these systems are just as likely to have increased the NVH quota for your car and the WEVO 997 SS Engine Mounts might be a somewhat transparent addition to your tuning regiment in terms of NVH.
Just to throw some more information out there...here's a link to my m.m. install and impressions. It's a wonderful product!
Wevo m.m. installed - impressions: https://rennlist.com/forums/showthre...ferrerid=19642
Ray (and/or others)
My car has allways had the original engine mounts but the engine carrier was bent in one corner.
Please check it, even if you have allways driven with the standard engine mounts.
The standard engine carrier is a deisign flaw. it is two weak or cracks.
As someone earlier in this thread says, if it breaks in an extreme case. You will be very unhappy.
