Does anyone recognize these clips
Trying to track down the part numbers for these with no luck. The broken one in the first picture plugs in the hole to the right with the circle in the second picture. It holds the power steering metal line. The second double clip on the left holds a wire plug. Thanks for any help . Doug
Thanks Vandit/Bob. Does anyone know the part # for the first broken one that goes in the hole on the right. It has no part #on it and does not show up on any parts schedule. It looks a bit like the clip on the front shock.
IHI KING!
I'm away from my car so I did a scan of PET while eating lunch. I didn't find the clip listed with the steering either. Here's a few possibilities.
911-602-551-00 Cable holder (PET 105-05)
944-347-467-00 Cable clip (PET 701-10)
Thanks Rob I ordered the 964 clip but did not see the 911 part. I have ordered a few each of every clip I could find. They are inexpensive and I will soon own the best inventory of odd clips in the north.
^This is the connector clip on the side of the engine compartment that you circled w/ a question mark. This clip is also found on the connector for the O2 sensor and on the connectors for both front ballast resistors.
See it here, 999.591.758.40
http://www.rosepassion.com/fr/cat/po...support/P69983
This is the other clip.
Confirmed here, 911.602.551.00.
http://www.rosepassion.com/it/cat/po...ggicavo/P17908
This clip is a bit different looking, does not match either of the clips in question.
See it here, 944.347.467.00
http://www.rosepassion.com/de/cat/po...schelle/P34765
