1993 964 C2 Coupe LSX/LS7 MODDED G50 Build
#61
wifes daily driver, hummer h3 alpha adventure. alpha; stands for "all options", all aluminum 5.3 ls v8, touchscreen nav, bluetooth hands free, leather, heated seats and mirrors, pwr everything, sunroof, etc etc etc. adventure; stands for 4:56 gears, front and rear lockers, 4:1 transfer case, factory 1" lift and factory 285/33" tall tires. since this pic it now has additional 2" lift and 315/35" tall bfg all terrains. so yes her sc ls1 911 is just a toy.
#62
my daily driver, 95 factory 1ton 4x4 suburban. special order sheriffs truck originally. 496ci tbi big block, 9.25ifs diff, hd 14bolt rear with g80 locker. 4:10 gears. borg 4401 hd transfer case, 3" lift and 35" bfg kevlars. doors are kevlar lined bullet proof, but glass is regular glass. fun driver tho. it will pull a freight train...
#63
#64
#65
Ruf964,
I too have been tempted by the swap. Few questions for you:
Are you planning to run heat & AC? If so, can you share the details? I live in Houston so AC would be a must.
What front bumper are you planning on using to accommodate the radiator?
I just posted these same questions on Don Nguyen's LS conversion thread.
Thanks!
Kyle
Thanks!
Kyle
#66
Ruf964,
Thanks!
Kyle
Thanks!
Kyle
edit; forgot the front bumper question. im running the stock 964 front bumper cover but i redesigned the lower openings to resemble the 993 turbo front bumper cover. looks nice imo and will be very effective.
#67
another clutch trick is to use a 964/965 pressure plate. start with a new one and a used one. take them both to your local clutch rebuild store. have them take the straps off both pp's and put 3 per location back on the new pp. it starts with 2 per location. this will make the lbs per square inch stronger by about 400-500ftlbs on the pressure plate without making the pedal effort much more.
#68
several ppl have asked... the ls wiring doesnt need integrated into the porsche harness. use a ls1 stand alone wiring harness and pcm with 5 wire hookup. retain the porsche ecm to run the chassis and dash. keep the porsche 964 engine sensors and adapt to the ls1. the only gauge you will need to alter is the tach as the ls1 pcm runs off a 4cyl signal. weird but true. so i have a 964 tach with 914 tach guts in it. or hollywood speedometer can make you one.
#69
#72
prices so far; 1993 964 c2 15900.00. sold low mile 93 3.6 for 6 grand, bringing initial monies down to 9900.00. bought g5052 internals for 1000.00. ls7 crate engine with harness ecm injection etc 18000.00. rsa tail came with car. rsa cage gift from porsche buddy 0.00. griffin aluminum radiator with elec fans 600.00. meziere water pump 250.00. 7075 stock for adapter parts 200.00. car had new bilstein nurburgring adj coilover shocks with hr greens springs when I got it. ss brake hoses, cross drilled rotors, rsa calipers/93/94 c2. other misc goodies but this is the bulk. so far @$27200.00 for 505hp with a g5052 gearset.
#74
