Ebay engine mounts - A word of warning!
Thanks - Just googled and there is a OPC 15mins down the road :-) I've given them a call and a pair of 993 C4 mounts will be available for me to collect tomorrow morning :-D
Still no word back from the ebay seller friend...
Sounds like your EBay mounts were junk.
Double check your torque settings too as if I recall correctly my Wevo mounts only required ~45ft/lbs. 85Nm is much higher!
RL Technical Advisor
Been there, done that. I had better luck with my Deutsche Technic Ebay motor mounts. I used them for a few thousand miles but I eventually swapped them out with 993 mounts. The difference in build quality is not small.
I agree with Steve. The only new 964 parts I buy on Ebay are cosmetic. I'm currently loving my new Ebay windshield visor clips and my new washer fluid cap
Technical Guru
ALL OE Freudenberg engine mounts for the 964 & 993, including the 993 C4 are hydraulic. However aftermarket OEM Corteco mounts are available in hydraulic and solid rubber versions. The rubber versions are for all intents and purposes (no idea how they differ in durometer), functionally the same as the 964RS & WEVO mounts. Meaning (just a word of warning) if anyone has ever tried to take off the engine mounts without first jacking the engine, they will likely require some bracing or an extra weld or two on their stressed engine carrier.
Doesn't make sense to me Mr. Simpson. I just used the 993 C4 mounts from Pelican Parts (Rein) on my 1991 C2 Tip and didn't run into any issues.
Basic Sponsor
The picture of that failed 'new' mount is tough to look at!
We offer a broad range of brands including Genuine Porsche, WEVO, Tarett, Mode & Corteco:
View 964 Engine Mounts
And as a reference, you can follow our step-by-step install instructions HERE
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
