Project - BBS LMs
#47
No worries at all with handling etc at the moment.
Front archs are however rolled as car normally sits lower (suspension hasnt fully settled on photos since wheel swap).
Im spacing out the rears by about another 15mm and then lowering the front and dont expect too much of an issue
Chris
Chris
#48
Looks good Chris. The 993 door handles work well with the LM's. The chrome rose goes well with the polished rims...
You look low enough to me but good luck, sure it will look great.
#54
V6-R - I've used "Tuner" nuts with an internal key. These are more slim-line because the socket fits into, rather than on the outside of the nut.
When we researched the re-drilling it was decided to not countersink the holes, keeping as much metal as possible between the holes! Thats why I needed slim-line nuts
Merle - As far as I know you cant get these sizes anymore. I searched the world for my 4th wheel and it was only when the lads on this forum mentioned an 8x18 at Tire Rack that I was able to complete the project. If companies have them as listed they propably need to update their website (i.e. Vivid racing etc )
Chris
Chris
