964 Forum 1989-1994
Gearbox mounted speedo sender confusion
Old 05-13-2012 | 03:04 PM
Talat's Avatar
Talat
Default Gearbox mounted speedo sender confusion
Hello all,
Looking at the gearbox that I've taken out of my 1990 C4, it appears to have a speedo sender attached to it. My understanding is that from 1990 the ABS sensor is used for the speedo signal - if that is the case then why is the speedo sender still there ?
Is there a way to determine what is being used by the speedo ? The reason I ask is that I'm swapping in a later C2 gearbox which doesn't have this sender and would like to know if the speedo will actually work.
Cheers,
Talat
Old 05-13-2012 | 10:39 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
My 1990 C4 uses a transmission mounted speed sender too. If you want to try to determine if that sender is being used for your speedo, why not unplug it from the harness and take the car for a drive? The connector is on the side of the transmission.
Old 05-14-2012 | 03:18 AM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
Originally Posted by Talat
Looking at the gearbox that I've taken out of my 1990 C4...
Originally Posted by Rocket Rob
...why not unplug it from the harness and take the car for a drive?....
Driving it might be hard to do.....
Marc
Old 05-14-2012 | 09:49 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
My mistake. I missed that "key" piece of info. Thanks for correcting me Marc.
Old 05-15-2012 | 09:00 PM
Talat's Avatar
Talat
Sounds like once it's all bolted together I'll have to cross my fingers and hope for the best
Old 05-15-2012 | 09:07 PM
bassam's Avatar
bassam
here's your solution if you have to: http://www.speedhut.com/ i got one on my 964 and it fits fine.
Old 05-16-2012 | 08:10 PM
Talat's Avatar
Talat
Many thanks. Will contact them if all else fails.
Old 05-16-2012 | 08:22 PM
Sten's Avatar
Sten
It depends on what model of PDAS/ABS controller you have fitted - early C4's had 964.618.126.00, this is for use with the gearbox that has the magnetic pick-up in the transaxle. Later cars (91ish) used a different gearbox and picked up the Speed signal from the front left ABS sensor, passed through the later version of the controller 964.618.126.01 and then through a frequency converter in the Central Electric box to the Speedo. More info at https://rennlist.com/forums/964-foru...hangeable.html
Old 05-17-2012 | 05:54 PM
StanUK951's Avatar
StanUK951
Would this explain why the speed read outs between my OBC and analogue speedo differ? When my speedo reads 50 mph the rear spoiler raises but the digital OBC reads 55/56mph...
Old 05-18-2012 | 07:47 AM
Talat's Avatar
Talat
Thanks for this, most useful. So it looks like Adrian's book is wrong then.
Quick Reply: Gearbox mounted speedo sender confusion
