Which replacement clutch for modified engine?
So it's official - I'm getting a bigger, badder motor. To avoid controversy - let's say it's about 300HP.
The question now is which clutch?
I searched and searched and there's no defintive discussion around clutch choice. I have run both SPEC and ACT clutches in rally cars and loved them both. Dramtically better than stock, but those were japanese cars.
964 options include...
http://www.andysautosport.com/porsch...tch_kits/spec/
or...
http://www.titanmotorsports.com/actheduclkit1.html
Thoughts on these? What else is there?
This will be a street car only.
Thanks for your insight.
RK
or...
RK
Would you consider a 965 clutch?
$828 + shipping from Tischer Porsche. Would retain close to stock pedal feel I'd imagine (dunno how the aftermarket ones feel).
OTOH, I bet a good condition stock clutch would work out fine at 300hp, but I'm no authority on the matter. I've read a lot about the 300hp Motec 9M motors, and can't remember anybody suggesting an upgraded clutch (unless the stock one is already smoked). On a N/A motor, you're not gonna have the clutch killing torque levels of a FI motor...
single-mass flywheel is the same as the 996 and 997 GT3 clubsport Flywheel.
Pressure plate is quite changable. I use stock 964 pp, with sachs performance clutch disc (that fits for 996 GT3).
Throw-out bearing will be stock 964 RS...
the combination from pressure plate and clutch disc will define the max torque of the clutch assembly...
RK,
I am running close to 400hp in my 964 and I opted to spend the money and put a 996TT clutch in which is good for 500 plus HP.
This was recommended by Protomotive.
Jeff
Jeff
I kind of agree with the others there is a PORSCHE factory answer without going to some aftermarket nonsense.
Japanese car vs Porsche worlds of different. Japanese clutches always feel like a wet noodle.
Awesome feedback guys - thanks - and since there was no other thread along these lines - I'm hoping this will be helpful for others as well.
I have contemplated a LWFW (ala RS) but this is a street car with A/C - and therefore I don't want to go that route.
I'll keep the DMF and so - of the suggested options - which will and will not mate up with that?
964 Turbo Clutch?
964 RS Clutch?
996TT Clutch?
GT3 Clutch?
Thanks!
RK
964 Turbo Clutch?
964 RS Clutch?
996TT Clutch?
GT3 Clutch?
Thanks!
RK
