'Clicking' engine sound - trouble.
#121
But if the rockers are damaged in some way, it's likley to be caused by fatigue, not by something else deeper in the engine surely
In what way are they damaged?
I'm with the majority here, change the oil and filter, use it and ponder the next step
What is GT Ones opinion on the best course?
Craig's POV is to rebuild - he thinks that at this stage in the engines bottom end life and with the way I use the car ultimately it's the long term corse considering more damage could be done/ has already been done deep within.
He suggests I should drive it, change oil/ filter, carry out a leak - down test and reassess the right corse to take.
#122
Fingers crossed. It's the next step.
I don't know what way they were damaged - questions for Monday.
He suggests I should drive it, change oil/ filter, carry out a leak - down test and reassess to right corse to take.
I defo agree with Craig, but then again it's not my money.....
Should I have the truck and trailer on standby for Donnington!?
#123
If a rebuild is the only solution, you might as well use it, have the filter opened and the oil analysed.
A clear, simply worded description of the damage would help us keyboard experts tremendously. From what we have, it is at the best very foggy.
#125
You da man for the hottest prices
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
#127
How about, as an alternative....
http://www.ebay.co.uk/itm/1996-911-p...7#ht_500wt_715
http://www.ebay.co.uk/itm/1996-PORSC...#ht_1779wt_958
#128
Sign off? I've told Craig - who was as expected understanding, that I am looking at considering other specialist as well as GTOne should I take this corse of action.
#129
Here! i just sneaked out of a wedding reception for a quick catchup, yoink.
So the rocker can't have been too bad if they've put it all back together, or did they fit a new one? As others have said pics of the damage and a description in Peters own words would help us internet geniuses reasure you that GTOne are on the money (which they probably are)
My gut is saying change the oil and filter and run it, if it sounds right it probably is.
Gotta dash, they'll be sending search parties after me. . .
I'll give you bell tomorrow Frank.
#130
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Besides imagine if I did buy a replacement engine and it failed... you can't know the internal condition... also I'd rather keep a 964 a 964, if I keep.
A Dr is always on call - legend, thanks! I believe they've replaced the rocker - I'll find out...
#131
nah mate - i meant from the other alf re: "sign off".....sounded like she maybe wasnt on board that was all......even though it is your cashola........"happy wife happy life" and all that....
#132
Wouldnt even know what to start looking for with engine internals I'm afraid
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Bit of a minefield I think, unless youre just replacing with OEM there are so many upgrades available.
TBH if this was me, and of course Frank its down to how you feel in the end, however
I would change the oil and filter, run it and at the same time get an oil sample analysis to see if there ar eany serious contaminents left
Then if a rebuild was required I would go to someone like Richard Chamberlain or maybe Nick Fulljames for initial advice
Richard Chamberlain should certainly be able to advise should you want to upgrade in any way
#134
Or this... http://www.ebay.co.uk/itm/Porsche-91...ht_1290wt_1165 if only they were cheaper... ![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Grant,
Wouldnt even know what to start looking for with engine internals I'm afraid![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
#135
Hi, I'm intrigued up here.
I guess I am wondering about previous top-end work and whether it was done right? Experience with 356's tells me lots of people can fix Porsche engines, but not many can do it like the factory would. Its just in case your top end was recent enough for you to ask the guys that did the work some questions about this new uncharacteristic failure in the valve train...
Examining the oil and the filter for shrapnel, and running the motor if all clear is definitely what I would do too btw. Maybe consider a flush including oil cooler and lines too?
