rear spoiler update with questions
#76
More spoiler talk
1993 911; Spoiler locked in up position; no power, nothing; console switch does nothing; micro switches look OK (how can you tell?); when the console switch is turned do not hear anything like a relay opening or closing; greased the gear, WD 40 on electrical connections; is there a way to physically lower the spoiler?
Ant ideas? I may try the DIY solution on Bowman's blog; but first I have to get the spoiler down.
#77
More spoiler talk
#80
I'm thinking of doing this mod to my control unit.
Is there any reason I couldn't use a linear 50K potentiometer wired
to act like a variable resistor. That way I could adjust deploy speed on the fly.
The pot could mount to the outside of the control box.
Anyone done this?
Anyone done this?
#82
#83
That should work. I used a signal generator on a test bench with the module to make the graph, so not installed in the car. So in theory a pot in a car should work - calibrate the dial for mph's and you're good to go.
#85
Same part # but circuit completely different
Well, finally got around to the mojorizing mod, ie changing the resistor to modify speeds at which spoiler rises & drops. Pulled off the module case and discovered the circuit is completely different from the one pictured in that mod (see post 52 in this thread: https://rennlist.com/forums/964-foru...estions-4.html).
Mine is pictured below. Am I screwed? ie has the design completely changed so PLC programming is required instead of a simple resistor change? This is a '96 993 but the module is part # 964.618.212.00
Hoping mojorizing can chime in on this...
#87
I have a question; is there a way of modifying the earlier version to make the spoiler go up or down when you turn the main spoiler control switch?
Mine only goes up or down when stationary, it seems? Not when moving, is there a change to the controller that means I can actually control the spoiler myself with the round switch at any speed?
Thanks in advance
Thanks in advance
#88
I tried many times to get the one mojo made for me to work. I finally gave up. I wished it had come pre-programmed. Or that there had been clearer instructions for us "non-programmers"...cuz it really had been such a promising thing...and my spoiler still does its dance way too much. I just want something like down under 10 and up over 85. Easy breasy.
#89
I'm still fighting my spoiler issues too. But whittling down the possible problems.
I haven't heard from any other 1989 owners on their cars spoilers.
I'm still missing the relay for my set up and I'm on the hunt for one.
My guess at this point (haven't verified with a volt meter yet as I'm out of town) is that the controller is working, sensing the speed and tries to lift the spoiler but cannot.
I get the warning light on start up and then again when I get up to speed. And again when my speed drops down.
So it appears that the controller is warning me that it tried to lift and lower the spoiler but could not.
The mechanics of the spoiler work fine, I man manually lift and lower it and the motor works fine as I can hot wire it to lift and lower.
I don't know what the state of the micro switches are for max open and closed states. I'll measure those when I get home. Lots of good info on what to expect, voltage wise, from the micro switches here.
Question, Has anyone thought of using an Arduino to control this sucker? Very programmable. I've got a spare unit that I'm thinking of toying with.
#90
KLOKWERK - I had that problem when the fuse for the spoiler was blown. It's easy to check. If not the fuse then perhaps the micro switches are non-op or need calibration.
I just replaced the 39K resistor on the spoiler control module a few days ago. Spoiler now goes up at 62.5mph. So much better than the stock settings!!
