Valve cover powder coating (was "FUUUUU, I'm bummed...(long frustration rant)")
1. I live alone.
2. In between removal and blasting powdercoating I ran mine thru the dishwasher. Twice.
3. I don't buy the "we don't coat the insides...." argument. The factory ones were coated, and it DID peel off. Wtevr.
fiskarflugen (08-27-2019)
I washed them out in a hot soapy water last night prior to reinstallation and they cleaned up. I reinstalled them already. They look really sharp back on the car.
Since you asked.
![](http://img.photobucket.com/albums/v512/PumpXRS/IMG_0153a.jpg)
Now hopefully they went on right and they don't leak!
Now i'm on to replace the timing chain cover gaskets, chain tensioner gaskets, and oil bridge o-rings.
Nice!! Jealous.
Do I need to ask if you used a 1/4" torque wrench to slowly and accurately tighten the nuts so that the covers will not leak???
What's next on the list?
I used a small 1/4" drive ratchet and took my time going around tightening them down gradually, using a center and then working outward direction. I tightened them down as well as I could using such a small ratchet.
I don't have an inch/lbs or low lb range torque wrench, so i'm not sure know how close to 7ft/lbs I landed.
Next is replace the timing chain cover gaskets, chain tensioner gaskets, and oil bridge o-rings.
Hi vandit, I am waiting for the valve cover seals and fixing kit from d911 at the moment, I intend on powder coating mine after Christmas.
Just wondering if you have had yours off since you had them done and do you think it's ok to leave the insides bare still?
Thankyou
Thankyou
