ADVISE: V FAST ROAD/ TRACK TYRE UK
#31
I love the Bridgestone S02. I'm actually having new rear ones fitted again tomorrow. They are grippy enough for superb track poise and excellent on the road too. They are very predictable on the breakaway and consistent behaviour through the temp range as well.They do wear slightly quicker than some, but they're worth it.
Whatever tyres you want, I know a superb tyre guy in S London who will price them up better then anyone and fit & balance them perfectly (no affilaition).
#32
Like the sound of that!
Also - how would a track tyre like the R888's handle wet weather/slippery surfaces? Surely it would be a bit dicey out and about in poorer conditions on something like that.....given the UK climate is 11mths crap weather and 1mth of good weather...might be worth considering ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
They wouldn't perform better than R888 in the dry, but as an all rounder they're as close to being track tyres without any compromises.
Regarding wear, wet, hot, dry, road feedback, progressiveness, comfort they rate very highly.
Cheers,
#33
The place is in Sydenham in SE London called GT Tyres. It's a father and son outfit, they pay great attention to balancing perfectly and take proper care of your precious wheels while doing it. All for a great price. The number is 020 8699 3621. Speak to Graham or his son.
(I'd still recommend Bridgestone S02's and they are N rated for Porsche 964)
Cheers
Cheers
#34
I think the AD08 are only a slightly harder compound than the R888's and, as such, I would expect them to be similarly intolerant of low temps, I believe a standard summer tyre is deisgned to be used at anything above -30 deg C. If you want a single set of tyres to be used throughout the year and for a car stored outside, I would go with a performance oriented summer tyre such as the Bridgestone S02 that Seight recommends. Otherwise, try to pick up a cheap set of wheels wheels from ebay, I found some Cup 2's for £500 which I use as my track wheels.
#35
Care instructions for the AD08 from Yokohama:
The ADVAN Neova AD08 was developed using high performance compounds which become brittle at low temperatures and therefore should not be used in certain conditions. ADVAN Neova AD08 tyres thus must be stored or used only at temperature at or above -10°C (14°F) to maintain performance characteristics and to avoid any damage to the tyre or injury to persons or property.
Stated at the bottom of the 'Technologies' tab here.
#36
Cheers
Cheers
Just googled them, didnt realise that was where you meant, drive past them every day to work and back, good to get a recomendation
#37
I've been using Yoko AD08's for 2 years for autocross and street and they are outstanding.
In the winter I do store them in the garage. Yoko recommends not using them or storing them below 14 degrees F (changes the tire compound).
#38
What other tyre sizes would work on the car?
Fronts 8X18. Rear 9.5.
I'd like to reduce the aspect ratio/ profile, also maybe a tad wider.... (or don't I?)
I'm gathering that 245/ 35 would fit the fronts? Does that mean 225/ 35 would also work on the front?
How about 265/ 30 rear?
Thanks guys.
Thanks guys.
#39
+1 on that. I had the S02s shipped from the UK to the middle east because there was no N rated tires in the correct size. They handle great and look very period correct - on Cup1s they have enough grip to prevent the car from spinning wheels. Read somewhwere that there is a S03 N rated as well.
#40
Cheers
Cheers
#41
Come to me, my preciousssss
![](http://i106.photobucket.com/albums/m255/MX5_Dorifto/Porsche/911414.jpg)
Advan AD08s are on! in a 255/40-17 and 215/45-17...part of a local forum group buy
![](http://i106.photobucket.com/albums/m255/MX5_Dorifto/Porsche/911415.jpg)
Interestingly the AD08s look to be quite similar in tread pattern to the A050 racing tyre, but my first impressions are that they are quite quiet! Not as loud and rumbly as the Michelin Pilot Sports that they replaced.
![](http://i106.photobucket.com/albums/m255/MX5_Dorifto/Porsche/911416.jpg)
Gimme a few weeks for the new rubber to bed in, but so far they seem to be grippier than the MPS's (which admittedly were 5yrs old) but the big surprise is that the AD08s aren't wah-wah-wah noisy like motorsport tyres tend to be.
#45
I haven't had the car on the track yet, but for the street, the first thing I noted was that that were quieter than the Michelins. I was sort of expecting a lot of buzzy humming like you get with more aggressive track tyres but these are pretty streetable.
Dry grip, definitely a step up from the old Michelins (which also were well...old). Balance seems a bit different, rear grip is much more pronounced, and it's harder to break traction. I now have to turn the car in harder on the brakes as a result.
Wet grip, is also pretty good. Haven't noticed any aquaplaning or weird behaviour...so overall I'd say that these don't really seem like motorsport-oriented tyres, they just feel like expensive performance tyres.
I've heard that they are just 1s a lap slower than R888 though, so I'm keen to see if that's true
