Cup Bypass strap replacements
What kind of straps can be used to support a primary bypass pipe? I need to source some out and get mine mounted.
Yes, that is what I was thinking. Do you know what diameter works?
I don't recall, but I believe that they were the largest diameter that the hardware store carried. As mentioned, they need to go around the cup pipe and the mounting carrier. It should work! Good luck.
I would just look for new or reconditioned original straps.old straps.
If you have a porsche dismantler/parts center in the area it is not that hard. Most of the time you only have to replace the bolts. If you sandblast old ones which are in reasonably state, they can be like new again.
GL
GL
$40 for one?
http://cgi.ebay.com/ebaymotors/Porsc...-/370513776120
Somewhere someone posted that you could get similar straps at truck parts places.
"My clamp all tightened down is ~16"
Is that total length/circumference then? This would be around 5" diameter?
"The cup pipe is at least 3" in diameter, and the mounts around which they go add at least 4" .
7" diameter? 22" long?
Maybe this is an obvious question: How do bypass straps compare to the straps holding the stock muffler in place?
Basic Sponsor
If anyone needs new straps for there exhaust. Just let me know the size and I can send you a set for $60. Pm me if you need them or anything else.
thanks
thanks
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
cup pipe straps
I went through this with my cup pipe and like was said before I went to the hardware store and picked up two hose clamps cost $4.00 American and works like a charm. Nut driver or screw driver and all is done. cup pipe sitting in the garage usin the G pipe now but time to switch back and enjoy the other sound for a while.
