964 Forum 1989-1994
cylinder repair
Old 03-10-2011, 08:35 PM
cobias1
cobias1's Avatar
Default cylinder repair
has anyone ever used langcourt for cylinder repair ? going to send two of mine that have minor pits in them for repair and was looking for anyones experience. thanks in advance.
Old 03-10-2011, 08:40 PM
jimq
Burgled
jimq's Avatar
I thought the cylinders were coated inside and you could not redo them. Guess I heard wrong.
Old 03-10-2011, 08:52 PM
cobias1
cobias1's Avatar
dunno...just know that i was told at the machine shop they can be done and langcourt was told what type of car and im using mahle cylinders.
Old 03-10-2011, 09:27 PM
Dave White
Dave White's Avatar
They can be bored/honed and re-coated with nikasil, personally, I'd rather go used unless the cost was hugely different. Even then....
Old 03-10-2011, 09:35 PM
Makmov
Makmov's Avatar
They do it on small engines all the time Re-nikasil them. A lot of motorcycles, ATVs, Snowmobiles and personal water craft use nikasil.
I just don't think it's that common to referb Porsche cylinders.
Old 03-11-2011, 06:02 AM
cobias1
cobias1's Avatar
thats right..i read it in waynes book as long as they are the mahle cylinders with nikasil coating they can be redone. the alusil ones cannot according to the book.
Old 03-11-2011, 10:46 AM
Geoffrey
Geoffrey's Avatar
I use langcourt for boring and replating and have used US Chrome and Millenium in the past. The finish hone of the Langcourt is the best of the three as is the ability to keep to the tolerances. You'll want to measure the height of the cylinders when they come back to ensure that they have been machined properly. You can't do just one because they take a small amount off the top after the process is complete. With any of these processes, you'll lose the taper Mahle puts into the cylinder from the factory.
Old 03-11-2011, 11:19 AM
Steven C.
Steven C.'s Avatar
Geoffrey,
So does this mean a slight bump in compression?
Old 03-11-2011, 09:00 PM
cobias1
cobias1's Avatar
so are you saying do the opposing cylinder of the opposite when doing this ?
Old 03-11-2011, 10:29 PM
crg53
crg53's Avatar
All the cylinders should be the same or you will run into other problems. The height of the cylinder when installed in the case has to be the same all the way around as do the heads, or you will have problems with the cam shaft bore alignment and the sealing of the cam tower to cylinder heads. Due to the way these engines are designed it is of extreme importence that these items are in matched sets.
Quick Reply: cylinder repair
