964 Forum 1989-1994
LONDON 964 OWNERS - 12th meet 4th Dec- PICTURES!!!
Old 11-06-2011, 02:11 PM
  #601
Strega(UK)
Strega(UK)'s Avatar
Looked like a great day, shame I could not make it as I have the inside of the car dismantled for my harness fitting project!
Old 11-06-2011, 02:26 PM
  #602
Porsche964FP
Porsche964FP's Avatar
Oooo, what harnesses you planning? Truss, bar?
Old 11-06-2011, 02:58 PM
  #603
freedman
freedman's Avatar
Great pics Frank, looks like a good day
Who's is the Blue K plate? Absolutely lovely
(as they all are of course, but I've seen all the others before )
Old 11-06-2011, 04:24 PM
  #604
apw2007
apw2007's Avatar
Great pictures, cars, drive, company and food but eating outside in November was not 'great'!
Old 11-06-2011, 06:43 PM
  #605
Havana Henry
Havana Henry's Avatar
That's me
Really good to meet you all today. Frank, thanks for organising. Tony, thanks for taking us down those great roads, at proper speed too
Old 11-07-2011, 04:36 AM
  #606
Strega(UK)
Strega(UK)'s Avatar
Frank, as you know I like to keep things as Porsche intended so am trying to fit the harnesses to the rear parcel shelf. This however is not without a load of head scratching as I have no source for guidance!
My plan so far is to fabricate a piece of steel box section that will be bolted onto the rear shelf using the current 4 belt mounts, this I will use to attach the anchors for the harnesses.
The rear shelf can then be covered in carpet and it should look factory!
Old 11-07-2011, 08:27 AM
  #607
J81 JKR
J81 JKR's Avatar
:James,
Is your rear bumper centre section a genuine RS part? If not would you mind telling me where you got it, design911?
Thanks, great car (in the best colour!!)
Old 11-07-2011, 10:10 AM
  #608
clinchy993
clinchy993's Avatar
Cheaper from Camtune or OPC Byfleet as the official title now is ,well it was 2 months ago when I bought mine
Old 11-07-2011, 10:41 AM
  #609
Nski
Nski's Avatar
From the pictures looks like a very nice meet with a bunch of fellow 64ers that day. The cars look fab and nice to see there getting used especially coming to these climates. Winters biting in soon, will there be any more meets?
Keep the 964 dream alive boys!
Old 11-07-2011, 10:51 AM
  #610
Havana Henry
Originally Posted by J81 JKR
:James,
Cheers. Not sure about the bumper as it was on the car when I bought it. See above for more relevant info...!
Have emailed you Tony, cheers.
Old 11-07-2011, 11:57 AM
  #611
Porsche964FP
Sounds interesting! Look forward to seeing the results!
Old 11-07-2011, 04:35 PM
  #612
J81 JKR
J81 JKR's Avatar
Thanks clinchy!
Old 11-07-2011, 06:25 PM
  #613
Barty964rst
Barty964rst's Avatar
I thought the rear shelf already has 4 bolt holes where you can attach the harness's. These would be under the parcel shelf,would necessitate 4 bolts to locate.
Old 11-08-2011, 05:30 AM
  #614
Strega(UK)
Strega(UK)'s Avatar
You are right in that there are 4 nut anchors there, however 2 are for child seats and am not sure if they are up to the job! The other 2 are obviously ok as they were intended for the rear inertia reels.
Any thoughts on this will be greatly appreciated. I wish I had looked at your car harder last time i saw it as am sure you probably have this set up already.
Old 11-08-2011, 09:21 AM
  #615
Barty964rst
Harness's are clipped into these bolt holes for a lot of 964 Lightweight's and 964 Track cars using the harness option. I have these 4 holes in use for my 993 harness, along with seat belt anchor points for the 4 point harness.
The cars with welded cages, N-GT and Cup's use the roll bar directly behind the driver to anchor the harness, as per factory set up.
So it would seem you could consider using these existing bolt holes, rather than engineer an alternative solution.
There must be a fellow 964'er on here that has stripped or have stripped the inside of a Carrera to verify the above?
Quick Reply: LONDON 964 OWNERS - 12th meet 4th Dec- PICTURES!!!
