Cup floorboard fittings
Is it still possible to buy the bracket and or the cupped washers that the factory used to fit the floorbaords
I know Rennline supply them with their own floorboards but does anyone, or the factory still supply them individually?
I spent a good while at my OPC while the parts guy who looked through all of their parts catalogues but we had no joy in finding the cup washers
So I made my own floor boards from plywood and used normal screws and washers to fit them. The Rennline boards look great but I wasn't sure if they would fit a RHD car and I thought they were a bit pricey for what they are too.
Some pics of the floor and fittings here - http://www.flickr.com/photos/lappies...7603257099709/ - I took these for someone else who wanted to make a similar floor, also traced out a template of the board. RHD would presumably just be a mirror image. Something to be aware of is that the cup had metal mounting brackets for the floorboard welded onto the floorpan.
No, the floorboards and washers are out of stock at Porsche Motorsport for good. I tried to buy the parts some years ago but it was "to late". I ended up making copies of all the parts with a friend of mine. We used another friends Cup-car as a template and then had the bracket and washers made. Then we did the plywood parts ourselves. We made the kit for both sides. The end result looks really good :-)
Thomas
Thomas
Opening an old thread. I believe similar washers can be purchased from Mcmaster Carr they are called Cup Washers for oversized holes (Just confirm the size you need part number 92856A103 for reference).
