My 'RS' inspired road going 'Cupish' car project
#136
I'd watch out for some of those wheel dimensions. I found a few inconsistencies for the same wheel on different websites.
I went for the 320mm 997 RSR wheel. It was a big jump going from the stock wheel to 320mm but after a month or two, it feels great and definitely not too small.
BTW ... dont go for suede .. mine is starting to get greasy after a few months! ... luckily the OMP Superturismo is also available in leather although I just wish I'd bought the leather not suede.
#137
The ride on mine is no where as firm as I thought it would be.
There are some pics on my site www.cagedcar.com
#142
Hi Lee,
What hardware did you need to mount the SPG seats? Did you use standard Recaro mounts and runners?
I'm looking to fit a SPG in my RS (better fit for me than the standard seats), but I can't figure out what parts I'll need other than the seat itself.
Thanks,
tat
Thanks,
tat
#143
Hi Tat,
You will need the side mounts from Recaro or Southbound. The Southbound ones sit a little lower but I went with Recaro which is what the Cup spec RS had.
You will also need Recaro runners unless you want fixed position.
2 x Recaro SPG's
2 x Sidemounts
2 x Runners
Let me know if you need anymore help, I can get good prices on these.
Cheers
Lee
#144
Hi Tat,
2 x Recaro SPG's
2 x Sidemounts
2 x Runners
Cheers
Lee
2 x Recaro SPG's
2 x Sidemounts
2 x Runners
Cheers
Lee
So I guess I need a set of Recaro runners. Will these bolt directly into the car without modification? The standard runners attach to the car with 3 M8 bolts each side - one at the front and two at the back.
Really appreciate your help!
tat
#145
Hi Lee - thanks! I'm only going to change one seat. I've bought a SPG and a pair of sidemounts, but I've found that the sidemounts won't fit on the standard runners - the bolt holes are in different places.
tat
tat
Hi Tat,
The Recaro runners will bolt to the car without any mods. Mine are fixed at 4 points to the car.
With the items I have listed you will be fine.
Let me know if you need any further info.
Cheers
Lee
#146
#147
#149
