cam regrind
1) Can the 964 stock camshaft be properly reground to meet the 993SS specs? I have found one shop that says yes and another says no.
2) Is it possible to identify characteristics of a cam profile which support low/mid torque development versus top end hp? Or am I off in newbie-land because it's a lot more complex than that?
I am not a racer but instead looking for street and AX/DX performance improvements.Thanks for any knowledge and direct experience you might have to offer. These are anxious times for me since my rebuild was somewhat suddenly forced on me due to increasing oil leaks - left me scrambling to figure out how to efficiently investigate and incorporate any enhancements.
1) Yessir, your cams can be welded and reground (this prevents going down beyond the base circle), however new billets are recommended.
2) There are VERY few cam profiles that work with the stock OEM single-throttle intake system so your real-world choices are limited to stock (perhaps tweaking the cam timing a tad) or the 993SS ones. These latter ones shift the effective RPM range up a bit without compromising bottom-end torque very much at all. We usually go to the trouble to install larger intake valves to take full advantage of the cam upgrade,....
Hope this helps,
Hope this helps,
-993 Super Cup (modified): duration-248/234, lift-.490"/.455", lobe center-114 degrees
-Sport 964: duration-248/238, lift-.490"/.470", lobe center-112 degrees
-Web Cam 993SS: duration-260/240, lift-.490"/.446", lobe center-112/110 degrees
Thanks for your time and expertise!
They do a DC21 camshaft which works well with stock 964 engines and is one step up from a supercup camshaft. I am advised they work well with intake and exhaust upgrades and will also work with an aftermarket chip.
I have been told that with all else stock, they see around 25-30RWHP which by my very rough calculations should be around 25kw at the crank.
ie: 25-30hp x @1.32 (for drivetrain loss) gives 33-40hp crank. Which is 24-29kw at the crank.
They are very well priced for new billets.
Mine are going in next week so I can let you know how they go.....
So far so good, I've had a pretty good experience with them. Plus, it didn't cost me a fortune to get them done.
(no affiliation with Elgin Cams. I'm simply a customer)
Don't judge this guy from his website. I met him face to face, and he is truly old school. He has much more experience with cams than he does with keeping his site up to date.
I won't tell you which cam to use, but I will tell you that cams with 112 deg LC's will cause you grief (idling, surging, etc) so whatever you decide on, I'd suggest maintaining the stock 114 deg LC's and you'll be quite pleased.
JMHO, but I think Dema Elgin is THE best cam person out there.
Thanks very much!
240 deg Intake duration (@1 mm basis)
230 deg Exhaust duration (@1 mm basis)
.470" Intake lift
.430" Exhaust lift
113 deg lobe angle
1.26 mm overlap
In looking for a higher performance cam profile I want to make sure I am comparing it to the correct stock data.
Thanks!
You can see that there is not much difference between all parameters except for overlap. Steve W, I took your comment to heart about the lobe center angle as you can see it is identical to stock. Dema obviously agrees with you. Despite trying to find out more about overlap and the effect of its variation, I must confess I am not sure why Elgin chose to nearly double it for his Super C-2 versus the stock cam. I didnt notice the difference until after our telcon. Any thoughts or concerns?
In case youre wondering why I am only marginally upping the performance of my camshafts, my reasons are (FWIW) - the regrind is reasonably economical and quick, I am already upping my displacement to 3.8L, and I am getting more cautious because of worry about the risk of making too much of a change. I am also having Steve Wong make me a custom chip, so I think that will get me where I want to be without being too greedy.
BTW, Dema will also polish the rocker arms and QC the bushings.
So, that is where I am heading. As always, any comments are of interest to me. Cheers.
According to the Dougherty website, the DC21 has a 112 deg lobe angle. Their DC 20 is called Super C2 and looks to be essentially the same as the Elgin Super C2.
I look forward to hearing how things turn out for you - hope it goes well and gives you what you were looking for.
Amazing how the complex nature of cam profiles and their effect on performance, when combined with personal tastes, can make it so hard to decide!
