Is there a trick to seperate the AC lines?
I need to disconnect the high pressure AC line that is under the rocker panel. I put a wrench to both sides and and could not budge the nut (left side) at all. Given the nature of the aluminum lines I don't want to do this incorrectly and twist the tubing and make a mess out of what should be a simple job. So is there a trick to separate the lines. Does Porsche use some sort of thread sealant that could be keeping this together? I assume that I am trying to turn the correct nut?Any suggestions would be great.
+1 on the lube. Also heat the nut to no hotter than the temperature that makes water sizzle (aluminum starts to anneal at around 100 °C). Heat it fast, and the thermal gradient will budge the threaded interface just enough to make it easier to start moving. You can also put a chill on the inner parts. Electronics supply houses sell a spray used to chill electronic components.
