964 Forum 1989-1994
pulled the a.c. compressor
Old May 17, 2010 | 02:08 PM
yertyat's Avatar
yertyat
Default pulled the a.c. compressor
and i'm pleased w/ the results.
File Type: jpg
File Type: jpg
Old May 17, 2010 | 02:35 PM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
Now, now... don't stop there... remove those unecessary brackets and mount...
Old May 17, 2010 | 03:08 PM
ThomasC2's Avatar
ThomasC2
Yeah, you´re only half done! There's 18 kg more to go!!
Thomas
Old May 17, 2010 | 03:56 PM
elbeee964's Avatar
elbeee964
Well done.
Looks like you're set for the imminent fall of civilization. (below)
(I, for one, would Not want to be on the receiving end of your hose-handled flail.)
Old May 17, 2010 | 04:09 PM
Boeing 717's Avatar
Boeing 717
Registered User
Dang dude looks like a serious weapon!!! Dont slam it against a wall or anything.
Old May 17, 2010 | 04:12 PM
yertyat's Avatar
yertyat
Default big fun
that's good to know. i didn't want to get too ambitious.. -already have a box w/ close to 40lbs. of parts that i've removed w/ no problem. i plan to do a little research before i go after the rest of it.
Old May 17, 2010 | 04:15 PM
yertyat's Avatar
yertyat
"hose handled flail" -i was hoping someone found that amusing. saw the picture and thought the same thing. it's by far the most dangerous looking thing that i've pulled out of the car so far..
Old May 17, 2010 | 05:01 PM
BVF's Avatar
BVF
Thread jack! but it's related. Just had a single belt conversion done so im looking for a DIY or some guidance on how to remove all AC related components. Currently only the AC compressor is removed. Where is everything else located? Thanks
Old May 17, 2010 | 05:24 PM
xeps's Avatar
xeps
For starters, there are two a/c lines in the engine bay that can be removed if they weren't taken out along with the compressor.
Also right back there is the a/c bracket - it's aluminum and can be cut down if you do not intend to run a/c in the future. It is fairly tricky to get the bracket out in the first place and requires removing the engine carrier and swindling the bracket past the crank pulley.
That's as far as I have gone with a/c removal..
Old May 17, 2010 | 05:26 PM
xeps's Avatar
xeps
Did you cut the lines to get them out? Looks like it in the photo..
Old May 17, 2010 | 05:36 PM
yertyat's Avatar
yertyat
o.k., i cut the hoses, thats as far as i went. i'll have to do my homework but to get to the rest of it requires removing rear wheel, and wheel well panel? then would i follow the hoses up to the front of the car? i remember reading something about the compressor mount having to be cut. -wasn't ready to go that far quite yet...
Old May 17, 2010 | 05:42 PM
xeps's Avatar
xeps
I followed the lines only as far as the left side of the engine bay. There are two fittings there for removal - in fact, pretty sure they require the wheel to be off to remove.
The a/c bracket takes a fair bit of work. It essentially sits behind the engine carrier, and also has two little tabs on it that extend behind the crank pulley. It is relatively obvious how it comes off when you look at it, just a bit clunky to do the first time.
Once it is out, the material is soft and easily cut - but then there is definitely no going back.
Old May 17, 2010 | 05:47 PM
yertyat's Avatar
yertyat
"no going back",.. that happened a long time ago! thanks for the insight.
Old May 17, 2010 | 06:29 PM
RSGulp's Avatar
RSGulp
Old May 17, 2010 | 06:38 PM
boxsey911's Avatar
boxsey911
There's a thread on here somewhere that quotes the aircon components (compressor, hoses and condensor) as being 47 lbs. After lifting the box where all my bits got dumped into when they were taken off.....I would say that figure was pretty spot on.
