removing engine from trans
yeah, the cylinders were leaking a bit where they meet the case so I just said what the heck, why not do it now. So much work ahead of me though. Although some parts of removing the engine were annoying, like the throw-out bearing, it was still fun and enjoyable and I think that is what really matters in the end.
Professor of Pending Projects
FWIW: The first time I pulled the engine on my C4, I did exactly the same as you. I got to tell you though that putting it in was a real two man job. Not sure why, but I really had a tough time getting the upper bolts back in attaching to the engine. It eventually worked, but I wound up scuffing a bit of the flywheel in the process. I now just drop both as the install is much easier.
tom
tom
Yeah, after I pulled the engine I noticed that the trans torqued a little clockwise. This woried me but I figured that it was the lack of 400 lbs attached to it. I tried jacking up the trans just to see and it straightened out, but I do think that next time I will drop the whole thing. Oh well, I will know for next time.
Its going, have number 1,2,and 3 cylinders off, just waiting for the seals to get here and we should be in business!
The only thing that I really had to run out and get was a longer breaker bar for the head stud nuts. Everything else has come off as you would expect from a 20 year old car. Had the folks over for Christmas so work halted for a few days, but now its going again when I get the time. No wonder these cylinder seals fail, they are really thin little tiny pieces of rubber. Mine were all cracked and sticking the case.
Here are a couple of pics of the engine all naked, the box-o-left side of the engine parts, and the general state of the garage.
Does anyone know of a good, not harmful to the components, way of cleaning the carbon off of the combustion chamber and piston head? I really don't want to take them apart as a close inspection of the tollerances and components showed that they are all in good shape.
Just for reference, be very careful when torquing down some of the bolts, I sheared off two smaller ones by accidentally going to 9 ft/lbs instead of 7.5. I wasn't paying close enough attention and in a hurry, taking my time is the big lesson for later teardowns
