Battery Tray Rust
Battery Tray Rust
Found a nice little surprise yesterday.
I ripped up the rubbery material to find a lot more underneath. Always worse than it looks. The photo is after I spent a couple hours cleaning it up (grinding, wire brush with my drill). Some of the metal is eaten all the way through. This is definently a total loss of this piece. Anyone have an idea what this should cost to get fixed? Looks like you can just buy that bottom tray/sheet metal for about $230 (the entire piece). Another $1000 in labor?
Anyone know where to buy that tray for cheaper?
I do not see significant structural damage, but it is difficult to tell from the one pic. Get the rust off, and recoat with a professional coating system. Stay away from the gimmic rust treatments - they are for the yard furniture. The biggest problem you have is a leaking battery, and it did significant damage.
Use a sealed gell cell battery. First cost is not much more, and considering the damage done by acid leaks, gell cell is much cheaper to use in the long run.
Definitely beyond just getting the rust off. That piece needs to be replaced as there are points where I kept grinding away rust until I hit the undercoating.
The battery is new(ish) now. Should I get a battery mat once I replace the metal?
[QUOTE=mrmandmman;6937137].....That piece needs to be replaced as there are points where I kept grinding away rust until I hit the undercoating...../QUOTE]Rust does tend to perforate sheet metal, but replacement is not needed until the structure is compromised.
Get rid of the rust, apply a quality coating system. Seal any holes before the final top coat. That will be much cheaper and just as strong as welding in a new piece.
WOW ^^^^^
I'm going to check my battery tonight...
