Leaking ATF from Power Steering High Pressure Line?
Has anyone had this problem before. I know that leaking from the seals on the pump itself is fairly common.
I tried bleeding the power steering line, and this was when I noticed there was build up of ATF fluid under the banjo of the high pressure power steering line, coming off of the pump.
I replaced the two crush washers, but it is still leaking. What could be the cause of this?
thanks.
-Don
thanks.
-Don
IHI KING!
I've not had problems with the banjo fittings. I would try retorquing the fitting at first. If that doesn't work, I would remove the connection again, clean the area well and put on a new set of crush washers and be sure to torque it.
I have had some leaking from some of the high pressure line fittings going into the steering rack, but they were very minor, well actually, one day it burped out about a 3 inch puddle. For the easy fix I tried the lucas power steering fluid stop leak and I have had no problems since. Maybe if you still have a minor leak after you re-torque you may try it. Good Luck.
Burgled
It is still leaking quite a bit from there. Enough to cause smoke off of the exhaust every time I take the car for a drive. I might just have to try and replace the whole line, as part of the process of narrowing the problems down.
