Zimmerman drilled rotors
Hello all....this is my first time posting to this site. It was recommended by my last DE instructor that I take a look. I have already looked through many of the other posts and I am overwhelmed with the amount of knowledge on this site.
I really just wanted to start a thread so that I can post pics of my new zimmerman rotors and steel brake lines I am going to be putting on this weekend, hopefully it goes smoothly. Attached is a pic of the old girl (89 C4), waiting for our last run at Carolina Motorsport Park DE just a few weeks ago. All I have done to her so far is put H&R sway bars on her (not an easy task with the front dif. in the way) and put Michelin Pilot A/S's on her (great in the rain on the road and track by the way). She is great car and hope to have her many more years.
Agent Orange
Welcome!
Steel lines are not necessary. The factory uses stock rubber lines on their race cars.
I've had Zimmermans on my first 964 that I tracked with stock pads and was OK. Once I moved to more aggressive brake pads, they cracked. YMMV.
The directional drilling thing, in my opinion , just indicates a lack of willingness by the manufacturer to outlay a few more dollars on proper production methods. All the alternatives I've looked at have directional drilling or slotting and zinc coated hats so there's no reason why Zimmerman should not.
Welcome Ian, it's great to see your car with the war-paint on and looking for trouble! Feel free to post a few more pictures of you out on the track.
Neil
Neil
More details here:
https://rennlist.com/forums/964-foru...ml#post6491364
Neil
Neil
Any of the smaller 298x28 964 front rotors that are drilled were done after the manufacturing process and are indeed really drilled(as opposed to the oem cast in holes)
I think he is talking about the 'direction' of the holes. As in, on the right side, they look like they spiral outward or in the direction of rotation, but if you put them on the left side, they look backwards. Not so much the vanes on the inside as a 'true' directional rotor.
And I agree, it's a cosmetic thing, but it drives me nuts also.
10-4 on that rattlsnak. A/R, OCD.......whatever, I can't handle the fact that Zimmerman uses 1 pattern for left or right fitment. That's one reason I started looking for a value alternative to anything Porsche branded. Said branding adding an average of 486.2173% margin to the bloody part.
For me personally, brakeperformance was like a found money victory - $310 for the set of slotted rotors, side-to-side directionally correct, have thus far served as well as OE on both road and track.
If rotors aren't quite commodity, their damn close.
Very good point all.....I just now noticed that. As I am just getting into the modification thing, my OCD will probably get the better of me down the road and I will end up getting another set. I will still post pics of the job this weekend, hopefully without brake fluid all over the place. Thanks for all the input.
I also found some Australian made directionally vaned/slotted with zinc coated hats and temp paint for the same price as the Zims. It's the same brand used by most of the V8 Supercars. Bonus is that I'm spending it on a local product and doing my bit for the Australian economy. I gotta agree with mpeters about the whole branding vs price point issue.
I've spent a lot of time and effort modifiying my car to my taste but not as much money as I could have had I just gone with the OEM part every time. As has been mentioned time and time again on this forum, our older cars are now owned by enthusiasts who don't always have an unlimited budget for maintaining them. Porsche has already made the money on these cars from their original better heeled owners so it would be nice to see them adjust their parts for older car to a more realistic level.
Neil
Neil
Super Duper Moderator
Ian - car looks great.
GL with changing the rotors - easy but be careful with the small screws holding the rotors on as they are very soft. You might also want to paint the hats as I had Zimm's before and the hats tended to rust.
Marc
Marc
Australian Made Rotors
Hi Rotorheadcase,
I'm in Adelaide and am looking to replace my front rotors soon....what are you using on your car ? Where did you source them and did you do the install yourself ? Also...dare I ask....$$$$ ?
Mark
Mark
