My rear fan bypass box!
#31
Strange that you don't get the 2 seconds glitch. My car is a 1992, built in sept -91. Wonder if I maybe have an older version of my CCU compared to you. If so this means that this maybe works for older cars to (but with the 2 sec glitch).
#32
By PET are numbers for CCU follow:
964 659 047 00 till end of 1990 and
964 659 047 01 from 1991.
CCU in my car is with label 964 659 047 00. Shows like he is older unit.
No wonder by car with age 18 year and with 2 previous owners.
#33
OK, then mine is newer than yours. All this maybe just depends on luck :-)
Will be really interesting when more people here tries out this soloution so we can see if there's a pattern!
#34
Professor of Pending Projects
So you get rid of the rear blower (I guess you still have to put a bypass pipe in there), still have use of the heat (less of course since you do not have the rear blower sending all that heat inside), engine looks less cluttered... hummmm....
Photos of what an engine with this mod looks like?
#35
#36
#37
All, I jumpered the relay as indicated above in my '90 C2. Works exactly as it should, w/o delay in fan speed recognizing the speed setting. I used all points on temp dial with all speed settings on the other and is in good working order.
I did this with the resistors still in place. I think I'll pull those for the purpose of tidying up and report back. Thanks so much to those who have posted to this thread with real experience(s) and suggestions. I've been monitoring such with the hopes that someone would come up with a fix. Looks as though we're there, inclusive of early prod date cars. Mine is 3/30/90, with original CCU.
#38
Good to here! would be great if some more of you guys could try this fix. Regardless of if you have the bypass pipe or the blower installed. It would be good info just to understand if this is the "final setup" or if there any other issues. It's a very easy test to do, just remove the relay and connect the jumper cables as in in the pic.
Strange though that you don't got the hesitation on fan speed 4. So far it's only me...
#39
Hi,
first remove the rear blower relay. Then install two jumpers in same place. Connect 30 to 87 and 30C to 87C, or 30 to 87C and 30C to 87. No difference. 30 and 30C are anyway connected.
No more. You can now remove temperature probe and original resistor too, if you want.
Where do I send the check?
I have followed your instructions and have spent just 5 minutes fixing a problem that has been perplexing me for over 12 months
Subject to a full test (i.e a cold day - they are on there way) everything appears to work absolutely perfectly. My C2 was build November 21, 1990 and subsequently is a '91 model car. Previously, same as all early cars, my A/C would only work on the blue dot.
All hail Rennlisters.
#41
As DUCK states above, I'm also very interested if there is any possible fix or workaround for the '90 MY cars. In my case, my interior fan speeds will only work when temp setting is on full blue. As soon as you move the temp setting up, blowers die.
I'm assuming DUCK has the same symptom pattern on his '90 as I do on mine. FWIW when I did the install last year I'd followed the resistor spec DIY precisely/carefully.
Any help would be appreciated
Elliot
#43
I´m happy if somebody find, that this solution is useable ![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
don´t forget to disconnect rear blower plug. Without disconnecting rear blower start run in high speed.
Originally Posted by ThomasC2
....It's a very easy test to do, just remove the relay and connect the jumper cables as in in the pic.
#44
Thought we could find a solution for early 964s as it just needs to get 12V to the ccu pin G19 to fool it, assuming similar ccu in 964/993s? For 993s its a single jumper, looks like 2 jumpers for 964s but same approach. For 993 only works if the blower fuse is intack (although replaced for a smaller version) as this is the source of the 12v and codes on ccu are cleared.
#45
Or I missed something?
