Best way to route a boost gauge?
Agent Orange
As part of my winter "maintenance" the car is apart in the garage. So while I'm in there I was thinking of adding an analog boost gauge from the back of my supercharger to the cabin and mounting it where the radio usually goes.
I am not quite clear on how I should route the piping. I was thinking of possibly routing it from the back of the engine through at the top of the gear box, then down the central tunnel. Is that idea feasible? I don't really want to drill any holes in the body unless I have to. I'm also concerned about heat from the engine and gear box melting the rubber piping.
Any other suggestions?
Thanks!
Thanks!
I could check the wiring on mine. They mounted mine below where I think the ashtray was/is? Since I bought it supercharged I would have to trace the wire but can do that if needed.
-Dave
-Dave
I cannot remember on an RSA if the brake system is hydraulic or vacuum assisted. If vacuum assisted, I'd take it from the front of the car where it attaches to the brake booster.
I ran tubing thru the firewall, behind the rear deck, behing the rear quarter paneling, under the driver's inside door sill plate, and up to the a-pillar. I used a Mazda Miata gauge pod (IIRC) from jc whitney. I can only see the tubing for a few inches to the left of the front hood latch. I got the idea from Basal Skull (993TT forum).
Running thru the tunnel would be worth considering.
Agent Orange
Guys, I think I'm starting to get what you're saying. I'm not that familiar with forced induction, so please bear with me. Geoffrey, thanks for your help!
Should I be looking at tapping into lines 39 and 41 on the diagram below? Or am I completely off base here?
Thanks again!
Thanks again!
I would get the oversize gauge from auto meter which is over 3" and install it where the clock is. Worst comes to worst, you make a blank plate behind it.
One thing to consider is there is likely a check valve somewhere between the manifold and the brake booster so that the booster maintains vacuum when the manifold is in boost. Depending on where that check valve is will effect whether Geoffrey's idea will work.
Originally Posted by ilko
...Should I be looking at tapping into lines 39 and 41 on the diagram below? Or am I completely off base here?...
Now I'm curious about that check valve issue.
Agent Orange
Thanks! So if I run a coupler and a hose to the gauge in the cabin I should be good? Or do I need something else? Thanks again!
