964 Forum 1989-1994
Rev Limiter
Old Sep 8, 2008 | 10:36 AM
cornerhans's Avatar
cornerhans
Default Rev Limiter
I have a 1990 964 with a rev limiter that kicks in at 7200 rpm. I openend up the DME box to find what appeared to be a stock chip starting with the numbers 12xxxx.
It aslo looked like this was the first time the box had been opened. Everything I have read says the cutoff should be at 6800 rpm. Could someone advise on this? I do not want to blow up the motor.
Old Sep 8, 2008 | 10:42 AM
ilko's Avatar
ilko
Agent Orange
Has the tach been opened in the past? If someone played with it and didn't insert the needle properly, that could be the issue. Simple way of checking is to see if it idles around 840 RPM. If it does, disregard my post. If not, that may be the issue.
Old Sep 8, 2008 | 11:02 AM
cornerhans's Avatar
cornerhans
Tach shows a little over 800 at idle.
Old Sep 8, 2008 | 11:41 AM
DogInBlack's Avatar
DogInBlack
7200 bad-6800 good. Get confirmation that the tach works, or reprogram/buy another chip. 7200 doesn't really give any benefit since the power trails off around 63-6500
Old Sep 8, 2008 | 11:44 AM
dfinnegan's Avatar
dfinnegan
Do you have access to a Bosch Hammer? That'll display actual revs for verification. Though, I'm not sure where the signal comes from. Could be the tach?
Old Sep 8, 2008 | 12:24 PM
TR6's Avatar
TR6
Stock valve springs are not up to the task of running up to 7200 rpms. As someone else commented, best to get a replacement chip with 6800 limit if your current chip is allowing you to run up to 7200.
cornerhans's Avatar
cornerhans
I could install the DME from my track car (same year) and see where the cutoff happens.
Old Sep 8, 2008 | 12:41 PM
Geoffrey's Avatar
Geoffrey
I think you first need to determine if it is actually reving to 7200. What is the full number on the chip? If it is a factory chip, then I doubt it is overreving, but rather thr tach may be optimistic.
Old Sep 8, 2008 | 01:12 PM
cornerhans's Avatar
cornerhans
Geoffry-
I will remove the box again tonight and open it up to get the number.
Old Sep 8, 2008 | 03:26 PM
DogInBlack's Avatar
DogInBlack
If you have a tach issue, I have used and do recommend North Hollywood Speedometer- no affiliation
Old Sep 8, 2008 | 05:59 PM
elbeee964's Avatar
elbeee964
For the Hammer-challenged around here -- can ScanTool's numbers be taken as gospel?
(ie, insofar as accurately reporting what the ECU is perceiving in the engine's world?)
Just hoping that's a 'low fruit' case before going off to get some 3rd party-device's take on engine rpms.
Old Sep 8, 2008 | 08:06 PM
jimq's Avatar
jimq
Burgled
my scan tool seems to match my tach
