So what engine oil are you now using?
#92
I used 15W-40 three years ago. After that, i had two years with 10w-40 shell helix and now i use Meguine 10W-60. Significant better oil-pressure (mostly near 2bar when oil is hot (warmer than 90°) at idle).
#94
IHI KING!
I am using Mobil 1 V-Twin 20/50 in the 964's. I use regular Mobil 1 in my non-Pcars. I was a diehard user of Mobil 1 but recently disassembled my 964 with 230K miles on it. The cams had pitting. I spoke to my machinist and he said that this was caused by the lack of ZDDP. I have since switched to Mobil 1 V-Twin which has the high ZDDP that the red cap Mobil 1 had. The cost is only about $1 per quart more than the regular Mobil 1. I figure its insurance.
#96
IHI KING!
Laker - Yes, they dropped the ZDDP levels for a while 20/50 dropped from 1600ppm to 800ppm. I believe they have 1200ppm now. The V-twin has 1600ppm
#98
Brad Penn.
#101
Always interesting when these threads pop back up...
I have been using Redline 5w40 since I got the car, with usually one oil change per year as the car is stored for winter.
This year I will be switching to Redline 15w50 in advance of a US trip, where the car will see warmer temps than usual.
#102
Since this thread has been running for over 4 years since I first posted in it, do I get a re-up??
"What oil?" really is The Eternal Question.
Still Redline 10W-40. Nothing else, ever.
#103
http://www.opieoils.co.uk/pdfs/tech-...10w-60-oil.pdf
...same symptoms as I had experienced. So, on their recommendation I dropped it out, put 5W-40 in and the car feels normal again.
#104
I was loyal to Redline for a while with some of the older BMWs I owned. No reason other than what the internets recommended. Now I'm using Brad Penn 20w50 for the new (to me) 964, for the same reason. Will likely stick to it.
#105
Bought some 100% triple ester based oil from Maxima to try out on one of my motorcycles. Maybe I will also try out their Maxima RS 15W50 on my next oil change to see how my 964 runs. I would expect it to be similar to Motul 300V.
Currently running BP 20W50.
