DIY Belt Replacement for 964
Does anyone have a good website or tutorial Do-It-Yourself on the following belt replacement?
Fan Belt
Alternator Belt
A/C Belt
Is this essentially the same proceedure as the 993 set-up, with exception of the Distributor belt?
Any ideas on what it may cost for a Porsche shop to do the Distributor belt at $90.00 per hour?
Fan Belt
Alternator Belt
A/C Belt
In the tool kit that came with the car from the factory ,
hopefully , you will find two tools for changing the fan / alt belts .
"must restrain from being smartasss.............."
You say smartass , I say snark .
Snark is a good thing imho .
The car's handbook describes the replacement/adjustment very well. Put a cloth below the pulleys to catch any shims or bolts that you might drop accidentally while doing this job.
Professor of Pending Projects
Baby steps, baby steps. Soon you will be doing valve adjustments on your own. Remember that you must use all the spacers/shims, don't leave any out.
JTurbo- hope the belt change goes well. I should do that one day.
Thanks again,
I went to my local Porsche dealership today, left work early "for thanksgiving holiday" and picked up two belts for my 1993 RS America. The v-belts that they gave me for the alternator belt and fan belt was one 9.5 x 776 and one 9.5 x 760. Are these the correct belts? Which one is the fan belt and which one is the alternator belt?
Thanks again,
Use this link to change your belts if you can't find it in the manual (I haven't got access to mine today to let you know the page):
http://p-car.com/diy/vbelt/
Does anyone have the torque specs on each hardware nut and bolt that is removed.
Also, are the haynes manuals useful for the 964? Anyone have any leads to a 964 Porsche factory repair manual on CD? I got a 944 turbo factory repair manual on CD for $50 a couple of years back.
