Recaro Pole Position Seats Questions
Just a word of caution on using the OE sub bar mount. I had them on my GT3 seats and had a bit of a failure. I need to bring this to Porsche's attention. I can only assume this is a rare fluke but the bar on my drivers seat failed for no reason. It was properly installed and after 2 seasons of use one day at Lightning my wife came in and said the seat would not move. I looked underneath the seat and the mounting tabs just let go at the bends for no reason. Being in the metal business. The best I can tell is the tab was never properly hardened. You can actually see a line about 25% through the length of the tab that was hardened the rest was not. So both sides had a perfectly clean break without any force applied. The tabs were never bent prior to installation and the paint was in perfect condition.
I don't know how to describe it but I am posting pictures of the bar. I am sure this is not the norm and I have never heard of another occurrence but I have since switched my units out to the BK version. This is the best picture I can find although I know I have better someplace. The 2 colors to the right/left of the break show red where the bar had failed early on and black which was the part of the bar that was holding together most of its time in the car. You can see the shinny parts which were the last sections to hold before letting go. If this were involved in an accident it would have done nothing to help prevent serious injury.
I recommend checking your bars to be sure they don't do the same. I do find it odd that the problem was identical on both sides and that there is no evidence of any damage to the bar anywhere except at the point of failure.
I must have the original pic on another PC. I just figured I would try to relate my experience until I could find it.
The metal was cracked the entire length on both sides of the bar. 75% through from left to right or the closest section to you in the picture. leaving a section of metal maybe .040" by 1.5" holding the bar in place instead of the full cross section which is closer to .150" It is not so easy to get a good photo of the grain structure but the metal was clearly not tempered properly.
I will try to see what I can do by tomorrow. If i can't find the pic I will take another one.
Agent Orange
There needs to be a straight path, w/ 0-20* down angle from the shoulder top to the bar, if the pp holes are within that path then you are fine.
additionally w/ a Hans the shoulder belts need to be angled together, how far apart they are at the bar depends on the distance apart at the shoulder and the distance the bar is from the shoulder. But they definitely need to be angled in toward your body centerline.
