Track Use: Rear Hub Caution
Technical Specialist
Lifetime Member
Lifetime Member
Just got back from Watkins Glen, where a club members C4 sheared it's rear hub, just inside of the outside edge of the rear wheel bearing.
This seems to be a failure point, as I can think of two other C2's that sheared their hubs at the same place. With the hub in place, you can't inspect it without removing the hub from the rear wheel bearing, which also destroys the bearing.
When I replaced my rear bearings, I had one hub that had a small crack starting, and the other was questionable, so I replaced both of them. Here's a picture of the hub with a crack started, which is also just where the hub on the C4 sheared this weekend:
Just a caution for those that track their C2/C4's. If you replace your rear wheel bearings, be sure and carefully inspect your rear hubs. New ones are available from Porsche, around $375 each.
Lifetime Member
Lifetime Member
Do you suspect this is developed in hard driving/track cars only?
That said, if your rear wheel bearings are replaced, it presents an opportunity to inspect the rear wheel hubs.
The left side of the rear hub on my 964 cup was oblong shaped when we went to replace the bearings at the beginning of the season...I imagine it would have started to crack sooner rather than later...The car had about 13,000 kilometers (all racing) at that time.
Lifetime Member
Lifetime Member
are they not different on an rs ?
Cup car, however, uses a different part, 964.331.065.70.
Turbo and Turbo look also has a different part number, 928.331.065.07.
Lifetime Member
Lifetime Member
Hey Bill, your picture is zoomed in really close - do you have an image further back to show where that location is - I can't tell where it's at. Thanks
Lifetime Member
Lifetime Member
is it a rotating part, or a fixed part?
And what the diagram with part 7 doesn't show is the portion that inserts into the rear wheel bearing.
Lifetime Member
Lifetime Member
Bill, do you know of the guy was using spacers, or maintained the original offset? I would think that could be a possible etiology...
