Air intake temperatures with a cup/drilled airbox versus a stock airbox.
#46
Originally Posted by Red rooster
Colin,
Temperature is measured by a thermistor. A thyristor is a gate controlled power switch.
That's exactly why I stick to designing parts that move, but at least I got the th...istor bit right!
Point well understood about off WOT performance & temperature w.r.t. the stock installation around town and in "normal" driving conditions, but that does not detract from the fact that in general most punters would accept a small part throttle loss for the WOT gain, after all when was the last time anyone asked for a part throttle dyno comparison? As Jack said, a 5% loss of power at 2000rpm is overcome by application of 2% more throttle, so unless the engine is mapped incorrectly for the higher AT I also doubt that anyone would notice the difference.
Geoffrey, can you let me have the details of the fast response AT sensor, looks like it would be well worth fitting on our Motec turbo applications.
Also glad that you are gaining from the discussion Chuck, I personally get bored with the "which wheel/colour/polish/etc" debates and also enjoy the more technical posts and have also learned a lot from other Rennlisters.
#49
Colin,
There are tiny ntc termistors available from Siemens and a faster one from Bosch. The Bosch number is 0 280 130 085 and it has a standard 2 pin socket.
The specified time constant is < 5 seconds as opposed to the 20-40 seconds of the more standard type , like say the one found on a 993.
I guess it was Mark posting his measurements that kicked this off ! I have to admit some bias, as I advised him to replace a cone filter buried in the dark steaming recess of the engine bay with a standard snorkel lid when he got round to putting his car on a chassis dyno.
You will understand where I am coming from.
About time you got back to telling us about your heads etc !! as, apparently we are bored !!!!!!!!!
All the best
Geoff
All the best
Geoff
#51
Super Duper Moderator
If someone was willing to lend me a cone filter, I'll do the same test again with all three - just out of interest.
Marc
#52
Originally Posted by Lorenfb
A 4 page thread discussion that results in a possible +/- 1-2% power gain?
It must be a boring summer time for many!
Would you rather talk about polish......?
#53
Colin,
All the best
Geoff
All the best
Geoff
Thanks Geoff, and yes I understand the recommendation regarding the airbox on the dyno.
Hmmm, funny you should mention heads because we have recently carried out a test session at Elvington airfield with Total 911 magazine to measure the difference between standard and modified 993's with the 9m/4T heads, all recorded on an AX22 satelite datalogger. Had a mk1 GT3 there for comparison as well as my 400bhp RS. All I can say at this time is that the results were as expected given the results on the dyno. Keep an eye on the 993 forum in the near future.
#55
what interests me is why the cup airbox makes more power on the dyno? and does it do the same on the road? or have i missed the explanation! I can't beleive the factory did it just for noise!
#56
I have the cup airbox and my car has been running hot at the track, at the 248F mark. Does the warmer air coming in the airbox affect the oil temps? I am moving fast at the track, so I would think that the air would be cooler than when I am in traffic. I am debating on whether or not to go back to the stock air box to help lower my oil temps.
Thanks!
Thanks!
#57
I drilled holes in my stock air box and put a K&N Air Filter in as well as a Fabspeed Cat Bypass Pipe to compensate. There definetly is more power especially on the top end. Sounds cool too!
#58
The intake air temps don't have much, if anything to do with oil temps. Oil temps are a result of the combustion process 1500 degrees F or so, so a 20 degrees one way or another on the intake side isn't going to contribute much to the heat of the combustion process. Most C2s that are tracked require a secondary oil cooler to keep temps in line.
#59
Technical Guru
#60
Hi Jason,
I looked in the front bumper a few days ago and while there is some crud, it didn't look too bad. I will go ahead and clean it out though. I thought the fan overide switch was more for traffic than the track. I will look into all of these for sure as an oil cooler is very expensive and heavy. I will put one in if I have to and have ruled out the above.
Thanks!
Thanks!
