Diag interface & Software
#76
I've had good luck with Gregg's interface (schematic supplied with Doug's software). I couldn't get the Sipex chip, so made some minor changes to use a Max232 chip.
#79
Just some pictures testing the interface. Not very pretty, but works. Pretty comes later. I'm in two minds whether to cast a plug in resin, or machine one from plastic. The snipped resistor is R9 on Andy's interface (see previous post re: poor serial data levels from laptops). The ECU looks good, but I've some climate control issues to sort!
#81
I have an HP Compaq laptop without a serial port :-(( Maybe thats why the software does not want to run on it.
Will a 9-pin serial to USB convertor work? Else I will have to use my work laptop which has a serial port.
Just messing about with Andy's interface hooked up to com1 on my desktop machine produces no connection on the software. Is this correct? I assume I need 12V and some signal input to simulate.
#83
The fault codes on your climate control are most likely bogus. The CCU is very slow to "wake up" when probed by the scantool or the hammer, and a refresh or clearing the faults then re-scanning will likely show no faults.
I think dfinnigan covered this in his recent hammer thread.
#85
I picked up a USB convertor from a local computer shop for $15 and it functions just as a serial port. Has a driver CD to make the proper com port stuff in Windows. Works in 2k and XP.. I run my old GPS, newer GPS, and other serial stuff off it fine.
Mike
1990 964 C4 Targa
#87
Burgled
Originally Posted by puma1824
Can we get a breakdown of the over functions/capabilities this application can do?
Thanks in advance,
Puma
Thanks in advance,
Puma
#89
Hi robbed666,
Great pictures. As they say a picture is worth a thousand words.
I have bought an Andy Whittaker interface as a spare. I have had the same problem as you with L line not switching to 0v with both laptop & desktop PCs. Glad to see only led on L line needs cutting out, I had assumed K line led needed cutting also. Bit wet here so just bench testing it at the moment.
Pete
Pete
